Set Association Role (Utility Network Tools)
Summary
Alters the association role assigned to a network feature class or table at the asset type level.
Association roles define how certain network features participate in a utility network. A utility network has existing system-provided association roles for structures and containers. For a network feature to be set as a container or structure using associations, it is necessary to first set an association role. This is assigned at the feature class or object level for specific asset groups and asset types.
Learn more about how to set or modify an association role assignment
Usage
  • The view scale and deletion semantics for an asset type's role can be defined or updated with this tool.
  • The network topology must be disabled.
  • Unassigning container or structure association roles can only be done before the network topology is enabled for the first time. See Utility network management tasks for examples and their required network topology state.
  • When working with an enterprise geodatabase, the connected ArcGIS Enterprise portal account must be the portal utility network owner.
  • When working with an enterprise geodatabase, the Input Utility Network parameter value must be from a database connection established as the database utility network owner.
Parameters
Label Explanation Data type
The utility network that contains the asset type with an association role to set.
Utility Network; Utility Network Layer
Domain Network
The domain network that contains the asset type with an association role to set.
String
Input Table
The utility network feature class or table where the association role will be set.
String
Asset Group
The asset group that contains the asset type.
String
Asset Type
The asset type that the association role will be set for.
String
Role Type
Specifies the type of association role that will be assigned to the asset type.
  • Container—The container association role type will be assigned. Features or objects of this role type can contain other features and objects as content.
  • Structure—The structure association role type will be assigned. Features or objects of this role type can have other features and objects attached to them.
  • None—No role type will be assigned. These are features or objects that are neither a container nor a structure but do connect to other structures.
String
Deletion Semantics
Specifies the deletion semantics for the network features, which defines how content or attachment network features will be managed when the container or structure is deleted. This applies to both container and structure association roles.
  • Cascade—When the container or structure is deleted, all content or attachment network features will be deleted.
  • Set to none—When the container or structure is deleted, its content or attachment network features will not be deleted but will be removed from the containment or structural attachment association.
  • Restricted—If content or attachment network features exist, an error will be returned when attempting to delete the container or structure. The content or attachment network features must be removed before deleting the container or structure.
String
View Scale
(Optional)
The scale at which containment mode will be entered to edit features participating in the container. For example, setting the view scale to 5 means that when you enter containment mode of the container feature, the scale will be 1:5. Units are based on the utility network units, which are located on the Source tab of the utility network layer properties pane. This parameter does not apply to junction and edge objects.
Double
Split Content
(Optional)
Specifies whether the associated content of a container will be split if the container feature is split. This parameter is only enabled if the association role is container and is only applicable for line features.
  • Checked—The content of a container will be split if the container feature is split. If a parallel content line feature is found, the content will also be split and each section will be contained by the closest container feature. If the content line is not parallel, the content will be contained by the container feature that is closest to it. When the content is a nonspatial junction object, the content will be duplicated so that each container feature has a junction object as content. When the content is a nonspatial edge object, the content will be split so that each container feature has an edge object as content.
  • Unchecked—The content of a container will not be split if the container feature is split. If a parallel content line feature is found, the content will be contained by both sections of the container feature. If the content line is not parallel, the content will be contained by the container feature that is closest to it. When working with nonspatial junction object content, the content will be contained by the larger container. When working with nonspatial edge object content, the content will be maintained as content to both parent containers. This is the default.
Boolean
Derived output
Updated Utility Network
The updated utility network.
Utility Network
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
