Utility network management tasks
Configuration and management tasks within the utility network are dependent on many factors, including the type of workspace connection and its permission level, state of the network topology, and the version being referenced.
The following sections and tables provide an overview of the dependencies that exist for different types of network actions when working with a utility network. The following details are used to describe the various components:
  • Action—The tool or type of action being performed
  • Network topology state—The required state of the network topology
    • Enabled
    • Disabled
    • Prior to initial enabling of network topology
    • Currently not allowed
The following only apply when working with a utility network with an enterprise geodatabase:
  • Workspace—Specifies the required data source.
    • Service—The action must be performed against a feature layer from a service.
    • Database connection—The action must be performed against a database connection. For operations completed using a database connection, always ensure the workspace is set to branch for the versioning type.
  • Versioned data required—Specifies whether the action requires the dataset to be registered as versioned. The versioning type must be branch.
  • Database and portal utility network owner connection required—Specifies whether the action requires connections as both the database owner and portal owner of the utility network.
For further usage and examples, see An overview of the Utility Network toolbox.
Caution:
Certain network configuration tasks cannot be changed or are only allowed prior to enabling the network topology for the first time. Review Network topology state in the tables below for details on tools and actions impacted.
General operations
Action
Workspace
Default version only
Calculate Cluster Keys
Database connection
Disabled
Yes
No
No
Create Utility Network
Database connection
Disabled
Yes
No
Yes
Disable Network Topology
Database connection or service
Enabled
No
No
Yes
Enable Cluster Keys
Database connection
Enabled/disabled
Yes
No
No
Enable Network Topology
Disabled
Yes
Yes
Yes
Enable Network Topology (generate errors)
Database connection
Disabled
Yes
No
Data must be unversioned.
Yes
Rebuild Network Topology
Service
Enabled
No
Yes
No
Repair Network Topology
Database connection
Enabled
Yes
Yes
Yes
Update Portal Dataset Owner
Database connection
Enabled/disabled
No
Yes
Requires connection as the database utility network owner
Validate Network Topology
Service
Enabled
No
Yes
No
Verify Circuits
Service
Enabled
No
Yes
No
Verify Network Topology
Database connection
Enabled
Yes
Yes
Yes
Migrate To Utility Network
N/A
The Migrate To Utility Network tool generates an output mobile geodatabase.
N/A
N/A
N/A
N/A
Analyze Network Data
Database connection
Enabled/disabled
Yes
No
Yes
Apply Error Resolutions
Database connection
N/A
Yes
No
Yes
Network modifications
Action
Workspace
Load data
Enabled/disabled
No
No
No
Update service territory feature class extent
N/A
N/A
N/A
N/A
Editing a network
Action
Workspace
Create feature templates
Database connection
Enabled/disabled
No
No
No
Edit network features and attributes
Service
Enabled
No
Yes
No
Modify associations
Service
Enabled/disabled
No
Yes
No
Create or modify a telecom circuit
Service
Enabled/disabled
Working with start and stop locations requires the topology to be enabled.
No
Yes
No
Create or modify a subnetwork controller
Service
Enabled/disabled
No
Yes
No
Modify terminal paths
Service
Enabled/disabled
No
Yes
No
Modify terminal connections
Enabled/disabled
No
Can be from a database connection (if unversioned). If versioned, it must be from a service.
Yes
Update Subnetwork
Service
Enabled
No
Yes
No
Update Is Connected
Service
Enabled
No
Yes
Yes
Importing and exporting information
Action
Workspace
Export Associations
Database connection
Enabled/disabled
No
No
Import Associations
Database connection
Enabled/disabled
No
No
Export Circuits
Service
Enabled
No
Yes
No
Export Circuit Definitions
Database connection
Enabled/disabled
Yes
No
No
Import Circuit Definitions
Database connection
Enabled/disabled
Yes
No
No
Import Rules
Database connection
Disabled
Yes
No
Yes
Export Rules
Database connection
Enabled/disabled
No
No
Yes
Export Subnetwork
(without acknowledgments)
Service
Enabled
Yes
Yes
No
Export Subnetwork
(with acknowledgments)
Service
Enabled
Yes
Yes
Requires connection as the portal utility network owner
Import Subnetwork Controllers
Database connection
Enabled/disabled
No
No
Export Subnetwork Controllers
Database connection
Enabled/disabled
No
No
Export Trace Configuration
Service
Enabled/disabled
No
Yes
No
Import Trace Configuration
Service
Enabled/disabled
No
Yes
No
Tip:
A disabled network topology is recommended to import a large number of associations or subnetwork controllers.
Configuration changes
Action
Workspace
Add Color Set
Database connection
Enabled/disabled
Yes
No
Yes
Delete a color set
N/A
N/A
N/A
N/A
Add Color Scheme
Database connection
Enabled/disabled
Yes
No
Yes
Delete Color Scheme
Database connection
Enabled/disabled
Yes
No
Yes
Add Domain Network
Database connection
Disabled
Yes
No
Yes
Add Telecom Domain Network
Database connection
Disabled
Yes
No
Yes
Delete a domain network
N/A
N/A
N/A
N/A
Add Network Attribute
Database connection
Disabled
Yes
No
Yes
Set Network Attribute
Database connection
Disabled
Yes
No
Yes
Delete a network attribute
N/A
N/A
N/A
N/A
Add Terminal Configuration
Database connection
Disabled
Yes
No
Yes
Set Terminal Configuration
Database connection
Disabled
Yes
No
Yes
Delete Terminal Configuration
Database connection
Disabled, must be performed prior to the network topology being enabled for the first time
Yes
No
Yes
Remove a terminal configuration assignment—modify terminal configuration set from a user-defined terminal configuration to the default, or another user-defined terminal configuration.
Database connection
Yes
No
Yes
Add Network Category
Database connection
Disabled
Yes
No
Yes
Set Network Category
Database connection
Disabled
Yes
No
Yes
Delete Network Category
Database connection
Disabled
Yes
No
Yes
Add Tier
Database connection
Disabled
Yes
No
Yes
Delete a tier
N/A
N/A
N/A
N/A
Add Tier Group
Database connection
Disabled
Yes
No
Yes
Set or modify the subnetwork definition
Database connection
Disabled
Yes
No
Yes
Set or modify telecom circuit properties
Database connection
Disabled
Yes
No
Yes
Add Rule
Database connection
Disabled
Yes
No
Yes
Delete Rule
Database connection
Disabled
Yes
No
Yes
Set Association Role
Database connection
Disabled
Yes
No
Yes
(unassign)
Database connection
Yes
No
Yes
Set Edge Connectivity (modify from EndVertex to AnyVertex)
Database connection
Disabled
Yes
No
Yes
Set the telecom object combine or divide policies for grouped objects
Database connection
Enabled/disabled
Yes
No
Yes
Add, edit, or rename subtypes in the Asset group field
Database connection
Enabled/disabled
Yes
No
Yes
Delete subtypes assigned to Asset group field
N/A
N/A
N/A
N/A
Add, edit, or rename domain values in the Asset type field
Database connection
Enabled/disabled
Yes
No
Yes
Delete domains assigned to Asset type field
N/A
N/A
N/A
N/A
Add Trace Configuration
Service
Enabled/disabled
No
Yes
No
Delete Trace Configuration
Service
Enabled/disabled
No
Yes
No
Add Wavelength Scheme
Database connection
Enabled/disabled
Yes
No
Yes
Delete a wavelength scheme
N/A
N/A
N/A
N/A
