Import Trace Configurations (Utility Network Tools)
Summary
Imports named trace configurations from JSON format (.json file) to a utility network.
This tool can be used in conjunction with the Export Trace Configurations tool.
Usage
The input utility network must be version 5 or later.
The following requirements must be met when working with an enterprise geodatabase:
- The Input Utility Network parameter value must be from a utility network service.
- The Input Utility Network parameter value can be from a database connection established as the database utility network owner when connected as the portal utility network owner or a portal account with the administrator role.
The named trace configurations must be in a single
.jsonfile.The information in the
.jsonfile is stored in the following format:[ { "creator": "<property representing the connected portal account on creation>", "name": "<property representing the name for the named trace configuration>", "description": "<property representing the description of the named trace configuration>", "traceType": <property representing the trace type>, "configuration": <property representing the collection of trace configuration parameters>, "resultTypes": "[<property representing the types of results to return>]", "tags": "<property representing user provided tags>" } ]Example:
[ { "creator": "portaladmin_un", "name": "Connected_RMT002_A", "description": "Connected trace on subnet RMT002", "traceType": 1, "configuration": "{"includeBarriers":true,"validateConsistency":true,"ignoreBarriersAtStartingPoints":false,"allowIndeterminateFlow":false,"shortestPathNetworkAttributeName":"","traversabilityScope":"junctionsAndEdges","conditionBarriers":[],"functionBarriers":[],"functions":[],"outputFilters":[],"outputConditions":[],"pathDirection":"noDirection"}", "resultTypes": "[{"type":"elements","includeGeometry":false,"includePropagatedValues":false,"networkAttributeNames":[],"diagramTemplateName":"","resultTypeFields":[]},{"type":"aggregatedGeometry","includeGeometry":false,"includePropagatedValues":false,"networkAttributeNames":[],"diagramTemplateName":"","resultTypeFields":[]}]", "tags": "["connected","RMT002"]" } ]
Parameters
| Label | Explanation | Data type |
Input Utility Network |
The utility network to which the named trace configurations will be imported. |
Utility Network; Utility Network Layer |
Input File (.json) |
The |
File |
Derived output
Updated Utility Network |
The updated utility network. |
Utility Network |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
