Import a named trace configuration
Available with Standard or Advanced license.
The Import Trace Configurations tool allows you to import named trace configurations to a utility network from a .json file for sharing of named trace configurations across multiple utility networks.
Requirements
- The Input Utility Network parameter value must be version 5 or later.
When working with an enterprise geodatabase, the following apply:
The Input Utility Network parameter value must be from a utility network service.
- The Input Utility Network can be from a database connection established as the database utility network owner when connected as the portal utility network owner or a portal account with the Administrator role.
Follow these steps to import named trace configurations from a .json file to a utility network:
On the Analysis tab, in the Geoprocessing group, click Tools
to open the Geoprocessing pane.In the Geoprocessing pane, search for and select Import Trace Configurations.
The tool can be found in the Trace Configuration toolset of the Utility Network toolbox.
For Input Utility Network, specify a utility network.
For Input File (.json), specify the name and location of the
.jsonfile containing the named trace configurations.Click Run.
The named trace configurations are imported to the Input Utility Network.
The creator value in the .json file is honored during import. Since the portal utility network owner is the only user who can view and work with all trace configurations in a utility network, it is important to update the creator value as necessary to ensure proper access to the imported named trace configurations in an enterprise geodatabase.
To learn more, see Export a trace configuration and Import a trace configuration.
