Validate Network Topology (Utility Network Tools)
Summary
Validates features with dirty areas in the network topology of a utility network after edits have been made.
Usage
Inconsistencies between feature spatial edits and the network topology are marked with dirty areas.
When working with a utility network in an enterprise geodatabase, it is important to understand the validate operation is handled differently depending on the method used. The Validate command on the Utility Network tab uses synchronous processing, while the Validate Network Topology geoprocessing tool takes advantage of asynchronous processing.
Dive in:
The asynchronous validation process uses the UtilityNetworkTools geoprocessing service. The UtilityNetworkTools service is preconfigured in the System folder for feature services that include a utility network. It has a longer time-out setting and is reserved for utility network geoprocessing tasks.
The network topology must be enabled.
When working with an enterprise geodatabase, the input utility network must be a utility network service.
When working with the Default version in an enterprise geodatabase, only a single session can run the validate operation at a time. While the validate operation is running, the network remains accessible for editing and tracing.
When you validate a network topology based on a specific extent, the dirty areas that intersect the specified extent are clipped. To learn more, see Network topology.
A trace is used during validate to discover which subnetworks were modified. The results from a validate operation return the name of any subnetwork that is marked as dirty along with its domain network and tier in the response. The output JSON for these
Discovered Subnetworksvalues can be copied from theMessageresults in the details dialog box.In situations where a subnetwork is dirty before the validate operation is run, the collection of discovered subnetworks will still contain the subnetworks modified by the validate operation.
When working with hierarchical networks, if all the subnetworks in a tier are dirty, the tier is not traced during the validate operation. When this scenario is encountered, dirty subnetworks in the tier are not returned in the collection.
Failures may be encountered that prevent a validate operation from completing. When this occurs, use the Rebuild Network Topology tool to rebuild the network topology and repair inconsistencies. Rebuilding the topology within the extent ignores dirty areas and applies to all features in the specified extent.
License:
The active portal account must be assigned a license with the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
Parameters
| Label | Explanation | Data type |
Input Utility Network |
The utility network for which the network topology will be validated. |
Utility Network; Utility Network Layer |
Extent (Optional) |
The geographical extent that will be used to validate the network topology.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates. |
Extent |
Derived output
Validated Network Topology |
The validated utility network. |
Utility Network |
Output JSON |
The subnetworks marked as dirty during the validation operation. |
String |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Limited
Supported in an enterprise deployment when using ArcGIS Enterprise named user licensing with the ArcGIS Advanced Editing user type extension. - Standard: Yes
- Advanced: Yes
