Add Network Attribute (Utility Network Tools)
Summary
Adds a network attribute to a utility network.
A network attribute is a value derived from attributes on corresponding features in the network and is stored in the network topology. Network attributes are used in tracing analysis to control how the network can be traversed. While a network attribute can be associated with only one attribute on a feature class, there is no limit to the number of network attributes a single utility network can have. Network attributes are used as weights to control traversability and to model the cost of paths in the network.
Usage
  • A network attribute can be associated with only one attribute on a feature class; however, it can be associated with multiple feature classes.
  • When working with an enterprise geodatabase, the connected ArcGIS Enterprise portal account must be the portal utility network owner.
  • The network topology must be disabled.
  • When working with an enterprise geodatabase, this tool must be connected to the default version to run.
  • When working with an enterprise geodatabase, the Input Utility Network parameter value must be from a database connection established as the database utility network owner.
    License:
    The active portal account must be assigned a license with the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
  • This tool can be used with the Set Network Attribute tool, which assigns the network attribute to a feature class field in the utility network.
  • The following table lists the network attribute types and their applicable parameters:
    Attribute type
    In line
    Apportionable
    Nullable
    Substitution
    Short
    Check mark
    Check mark
    Long
    Check mark
    Check mark
    Check mark
    (Out of line only)
    Double
    Check mark
    Check mark
    Date
    Check mark
    Big integer
    Big integer network attributes are supported with Utility Network Version 7 and later.
    Check mark
Parameters
Label Explanation Data type
The input utility network where the network attribute will be added.
Utility Network; Utility Network Layer
Attribute Name
The name of the network attribute that will be added to the utility network.
String
Attribute Type
Specifies the data type of the network attribute.
  • Short (16-bit integer)—The field type will be short.
  • Long (32-bit integer)—The field type will be long.
  • Double (64-bit floating point)—The field type will be double.
  • Date—The field type will be date.
  • Big integer (64-bit integer)—The field type will be big integer.
String
In Line
(Optional)
Specifies whether the network attribute will be persisted in line. In-line network attributes are slightly more efficient, but the number of bits for user-defined in-line network attributes is limited to 25 per utility network. Store the most frequently used network attributes (for example, phase for electric networks, pressure for gas and water networks) in line if possible. The size of the bits is determined by the domain parameter. In-line attributes are only supported for integer network attributes (short or long).
  • Checked—The attribute will be added internally to the topology, making retrieval more efficient.
  • Unchecked—The attribute will be stored in an external table, and retrieval will require a call to the external weights table. This is the default.
Boolean
Apportionable
(Optional)
Specifies whether the network attribute will be apportioned across multiple edges belonging to the same feature.
Apportioned behavior is only supported with double network attributes. Network attributes with the apportionable property can be assigned to fields in line or junction feature classes, but only line features will have apportioned behavior.
For example, with the shape_length network attribute and a line feature that consists of five edge elements of 20 feet each in which the total length of that line feature is 100 feet, the attribute will be apportioned across all edges. For example, using a function in a connected trace to count the shape_length attribute for this line will return a count of 5 because it accounts for each individual edge element and not the entire line. The distribution of the value depends on the percentage along each edge element with respect to the from point of the original feature.
  • Checked—The network attribute will be apportioned.
  • Unchecked—The network attribute will not be apportioned. This is the default.
Boolean
Domain Name
(Optional)
The domain with which the network attribute will be associated. This parameter is required when In Line is checked. This domain is used to determine the number of bits to allocate for the in-line attribute and must be a coded value type. For example, the LifeCycleStatusDomain (0, Unknown | 1, In-Service | 2, Proposed | 3, Abandoned) domain has four entries, which means 2 bits are required to store the in-line attribute. The coded value domain must have sequential codes starting from 0.
Learn more about how to calculate the bit size for In Line network attributes
String
Is Overridable
(Optional)
This parameter is not used in the current release, and any value provided will be ignored. The functionality of this parameter is under development and will be applicable in a future release. Specifies whether the current value stored in the topology will be overridden using an external override table. This parameter can be used, for example, to input live data from external systems, such as present position in the case of electric or pressure value in the case of gas. An example is a SCADA system pushing the updated switching positions of Device A to the override table of the DeviceStatus network attribute, which the topology engine then uses to override its current value of device status for Device A with the override value.
  • Checked—The current value stored in the topology will be overridden.
  • Unchecked—The current value stored in the topology will not be overridden. This is the default.
Boolean
Nullable
(Optional)
Specifies whether the network attribute will support null values.
  • Checked—The network attribute will support null values. This is the default.
  • Unchecked—The network attribute will not support null values.
Boolean
Substitution
(Optional)
Specifies whether the network attribute will be used as a substitution. Substitution network attributes allow a substituted value to be used instead of bitset network attribute values during a propagation in a trace operation. Substitution is only supported with long integer network attributes.
  • Checked—The network attribute will be used as a substitution.
  • Unchecked—The network attribute will not be used as a substitution. This is the default.
Boolean
Network Attribute to Substitute
(Optional)
The network attribute that will be used as a substitution. Substitutions are encoded based on the number of bits in the network attribute being propagated. The network attribute must be in line and an integer field type less than or equal to 8 bits.
String
Derived output
Updated Utility Network
The updated utility network.
Utility Network
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
