Enable Cluster Keys (Utility Network Tools)
Summary
Creates a CLUSTERKEY attribute field on classes in a utility network. This attribute field is updated by the Calculate Cluster Keys tool with values that facilitate the grouping of features and objects in the network topology.
Cluster keys enable analytical operations to be performed more efficiently in the utility network when working with nonspatial junction and edge objects. The cluster keys are consumed by the network topology on enable and can be helpful when running operations that query the network topology, such as a trace.
Learn more about working with cluster keys
Usage
  • This tool modifies the schema of the utility network classes.
  • When working with an enterprise geodatabase, the Input Utility Network parameter value must be from a database connection established as the database utility network owner.
  • An exclusive lock must be obtained, meaning that you must close active connections to the dataset, including those from services.
    License:
    The active portal account must be assigned a license with the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
Parameters
Label Explanation Data type
The utility network containing the classes to which the CLUSTERKEY attribute field will be added.
Utility Network; Utility Network Layer
Derived output
Output Utility Network
The updated utility network.
Utility Network
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
