Import Circuit Definitions (Utility Network Tools)
Summary
Imports circuit information from a series of .csv files into the circuit management tables of a telecom domain network.
The .csv files generated by the Export Circuit Definitions tool can be used as input to this tool. The imported .csv files will populate the Circuit, CircuitSection, and Subcircuits tables with information about the components that compose circuits in the telecom domain network.
Usage
The Input Utility Network parameter must reference a utility network that contains a telecom domain network.
The features listed in the input
.csvfiles must exist in the utility network.The Circuit, CircuitSection, and Subcircuits names must be unique in the telecom domain network and cannot exceed 124 characters.
Nonsectioned circuits can be imported and created without start and stop location information; however, the start or stop location for a nonsectioned circuit may not be empty if the corresponding start or stop location is populated.
When working with an enterprise geodatabase, the Input Utility Network parameter value must be from a database connection established as the database utility network owner.
The
.csvfiles must contain the columns described in the following tables and conform to the specified format. Additional user-defined attribute fields can be imported when a field with a matching name exists in the target circuit management table.Circuit table .csv columns
Column
Example
CIRCUITNAMEThe name of the circuit that will be created. This must be unique in the telecom domain network.
23/ABC/123456/789/ER/1
STARTLOCATIONSOURCENAMEThe name of the feature or object class to which the starting point of the circuit applies. The name maps to the source ID for the class. The name is used when modeling a nonsectioned circuit with a single starting and stopping point. The name is NULL when the
ISSECTIONEDfield value isTRUE.TelcoJunctionObject
STARTLOCATIONIDThe global ID of the feature or object that is associated with the starting point in the circuit. This is used when modeling a nonsectioned circuit with a single starting and stopping point. This is NULL when the
ISSECTIONEDfield value isTRUE.{4E0AAF9B-F37B-433A-AC3B-EA385DD0AD92}
STARTLOCATIONFIRSTUNITThe first unit identifier in the range for the starting point of the circuit. This is used when modeling a nonsectioned circuit with a single starting and stopping point. This is NULL when the
ISSECTIONEDfield value isTRUE.1
STARTLOCATIONLASTUNITThe last unit identifier in the range for the starting point of the circuit. This is used when modeling a nonsectioned circuit with a single starting and stopping point. This is NULL when the
ISSECTIONEDfield value isTRUE.12
STOPLOCATIONSOURCENAMEThe name of the feature or object class used for the stopping point in the circuit. This is used when modeling a nonsectioned circuit with a single starting and stopping point. This is NULL when the
STOPLOCATIONIDThe global ID of the feature or object that is associated with the stopping point in the circuit. This is used when modeling a nonsectioned circuit with a single starting and stopping point. This is NULL when the
ISSECTIONEDfield value isTRUE.{1877F786-AD5A-4461-83C9-8A8B12479FF8}
STOPLOCATIONFIRSTUNITThe first unit identifier in the range for the stopping point of the circuit. This is used when modeling a nonsectioned circuit with a single starting and stopping point. This is NULL when the
STOPLOCATIONLASTUNITThe last unit identifier in the range for the stopping point of the circuit. This is used when modeling a nonsectioned circuit with a single starting and stopping point. This is NULL when the
ISSECTIONEDfield value isTRUE.5
ISSECTIONEDSpecifies whether the circuit is modeled with sections.
True
False
False
CIRCUITTYPESpecifies whether the circuit is a physical or virtual circuit. A circuit is considered virtual when it contains one or more sections in which the
SECTIONTYPEfield value isVirtual.Physical
Virtual
Physical
SECTIONORDERThe logical connectivity graph between sections for a sectioned circuit as a string in JSON format.
For example with a circuit consisting of three sections (1, 2, and 3), when section 1 is connected to section 2, and section 2 is connected to section 3, the section order would be represented as
{"1":[2],"2":[3],"3":[]}. Using an example with a circuit that consists of four sections (1, 2, 3, and 4), when section 1 is connected to section 2 and section 4, and section 2 is connected to section 3, the section order would be represented as{"1":[2,4],"2":[3],"3":[]}.When no connection exists between sections, all sections of the circuit are interpreted as being arranged in parallel, which could also be represented as
{"1":[],"2":[],"3":[]}.If no value is provided and the
ISSECTIONEDfield value isTRUE, an empty pair of curly braces are stored in the field to indicate that section ordering has not been defined for the sectioned circuit. This is NULL when theISSECTIONEDfield value isFALSE.{"1":[2,4],"2":[3],"3":[]}GLOBALIDThe optional global ID for the circuit. A user supplied GUID can be provided to serve as the circuit's global ID. This GUID must be unique in the telecom domain network. When this field is empty, a global ID is created for the circuit.
{6EBDCABE-571F-4DB0-AE01-4FDC81EBAE61}
CircuitSection table .csv columns
Column
Example
CIRCUITNAMEThe name of the circuit to which the section applies.
34/DEF/789123/456/ER/1
STARTLOCATIONSOURCENAMEThe name of the feature or object class to which the starting point for the section record applies. This maps to the source ID for the class.
TelcoJunctionObject
STARTLOCATIONIDThe global ID of the feature or object that is associated with the starting point. When the circuit section is associated with a subcircuit, this should reference the global ID of the subcircuit.
{939164F0-0EAA-4010-998F-64FAE34CA469}
STARTLOCATIONFIRSTUNITThe first unit identifier in the range for the section's starting point. This is NULL when the circuit section is associated with a subcircuit.
STARTLOCATIONLASTUNITThe last unit identifier in the range for the section's starting point. This is NULL when the circuit section is associated with a subcircuit.
6
STOPLOCATIONSOURCENAMEThe name of the feature or object class used for the stopping point in the section. This maps to the source ID for the class. This is NULL when the circuit section is associated with a subcircuit.
TelcoJunctionObject
STOPLOCATIONIDThe global ID of the feature or object that is associated with the stopping point in the section. This is NULL when the circuit section is associated with a subcircuit.
{33C63920-0057-44AC-AE69-8D841C6CEA2A}
STOPLOCATIONFIRSTUNITThe first unit identifier in the range for the section's stopping point. This is NULL when the circuit section is associated with a subcircuit.
STOPLOCATIONLASTUNITThe last unit identifier in the range for the section's stopping point. This is NULL when the circuit section is associated with a subcircuit.
ROLESpecifies the role of the section record in the circuit. This is used to identify the start, end, and midspan sections of a circuit.
This uses a system-maintained coded-value domain as follows:
Start and EndStartEndMidspan
Start and End
SECTIONTYPESpecifies whether the circuit section is physical or virtual.
Physical
Virtual
Virtual
GLOBALIDThe optional global ID for the circuit section. A user supplied GUID can be provided to serve as the circuit section's global ID. This GUID must be unique in the telecom domain network. When this field is empty, a global ID is created for the section.
{B3D62897-D2FF-40DD-8B23-10C9D6D4EAF4}
Subcircuit table .csv columns
Column
Example
SUBCIRCUITNAMEThe name of the subcircuit that will be created. This must be unique in the circuit.
32/SUB/012345/ER/15
PROVIDERNAMEThe name of the circuit in which the subcircuit participates.
34/DEF/789123/456/ER/2
GLOBALIDThe optional global ID for the subcircuit. A user supplied GUID can be provided to serve as the subcircuit's global ID. This GUID must be unique in the telecom domain network. When this field is empty, a global ID is created for the subcircuit.
{E35BFF25-3DCD-4951-AD73-10C1A02CB7F6}
Parameters
| Label | Explanation | Data type |
Input Utility Network |
The utility network to which the circuit definitions will be imported. |
Utility Network; Utility Network Layer |
Domain Network |
The telecom domain network to which the circuit definitions will be imported. |
String |
Input Circuits File (.csv) (Optional) |
The |
File |
Input Circuit Sections File (.csv) (Optional) |
The |
File |
Input Subcircuits File (.csv) (Optional) |
The |
File |
Derived output
Output Utility Network |
The updated utility network. |
Utility Network |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Standard: Yes
- Advanced: Yes
