Circuit management tables
Every domain network consists of a set of feature classes and tables with a fixed schema. When you use the Add Telecom Domain Network tool to create the telecom domain network, three additional tables (Circuit, CircuitSection, and Subcircuit) are created to support circuit management in the network. These system-maintained tables are read-only; however, user-defined attribute fields can be added for attribution.
Classes in a telecom domain network
The Circuit table stores information about the circuits in a telecom domain network. Each row represents a circuit and contains information about the sections that define it, when present.
The CircuitSection table stores information about the sections which define the circuits. Sections represent a collection of elements obtained through a single trace. A section can have multiple records in the table where each row represents a location (starting point, stopping point, or subcircuit) used in the section. Each section in the table must have one or more starting and stopping locations.
The Subcircuit table stores information about circuit subdivisions (subcircuits) which share the capacity or bandwidth of a circuit.
Information in the circuit management tables is updated when importing circuit definitions, when a circuit is verified, when the topology is enabled or validated, and when changes are made to a circuit. As with the other classes in a utility network, the circuit management tables are editor tracking enabled, and when working in an enterprise deployment, they are also branch versioned.
User-defined attribute fields can be added to the circuit management tables to store additional information about a circuit, such as capacity or ownership. These fields are editable through the the Create Circuit and Modify Circuit panes and can be configured to mark a circuit as dirty when modified using the Set Circuit Properties tool.
The circuit management tables are added to the map with the utility network layer and are also listed in the Contents pane for the active map.
Circuit management tables are included in the schema for utility networks that contain a telecom domain network only.
Circuit table
The Circuit table stores information about the following:
  • The name of a circuit.
  • The circuit status (Clean, Dirty, Invalid, or Deleted).
  • The last time information about a circuit was verified or exported.
  • When no sections are present (nonsectioned circuits), the starting and stopping locations that define the circuit are modeled using a single record.
  • When sections are present, information about section ordering that defines the logical connectivity between sections in a circuit.
The Circuit table has the following attributes:
Field name
Field alias
OBJECTID
Object ID
The object ID for the record in the table.
NAME
Name
The name of the circuit.
SECTIONORDER
Section order
Stores the logical connectivity graph between sections from the CircuitSection table as a JSON string. For example, with a circuit consisting of three sections (1, 2, and 3), if section 1 is connected to section 2, and section 2 is connected to section 3, the section order would be represented as {“1”:[2],“2”:[3],“3”:[]}. When no connection exists between sections, all sections of the circuit are interpreted as being arranged in parallel with the ROLE attribute value of Start and End. This is NULL when ISSECTIONED is False.
STATUS
Status
Specifies whether the circuit is Clean, Dirty, Invalid, or Deleted.
The Verify Circuits tool can be used to verify Dirty circuits and mark them as Clean. When errors are encountered during verify, the circuit is marked as Invalid. A status of Deleted indicates that the circuit has been marked as logically deleted. The Export Circuits tool is used to delete the record or records from the table when STATUS is Deleted and the Set export acknowledged parameter is checked.
Learn more about circuit status
LASTVERIFIED
Last verified
The last time the circuit in the table was verified using the verify operation or the Verify Circuits tool.
LASTEXPORTED
Last exported
The last time the circuit in the table was exported with acknowledgement using the Export Circuits tool.
STARTLOCATIONSOURCEID
Start location source ID
The source ID of the feature or object that is associated with the starting point for the circuit. This is used when modeling a nonsectioned circuit with a single starting and stopping point. This is set to Unknown when ISSECTIONED is True. The default is NULL.
STARTLOCATIONID
Start location ID
The global ID of the feature or object that is associated with the starting point for the circuit. This is used when modeling a nonsectioned circuit with a single starting and stopping point. This is NULL when Is sectioned is True. The default is NULL.
STARTLOCATIONFIRSTUNIT
Start location first unit
The first unit of the group associated with the starting point (for example, equipment unit ID). This is used when modeling a nonsectioned circuit with a single starting and stopping point. This is NULL when ISSECTIONED is True. The default is NULL.
STARTLOCATIONLASTUNIT
Start location last unit
The last unit of the group associated with the starting point. This is used with the STARTLOCATIONFIRSTUNIT attribute to define the number of units that are grouped in the edge object and is also used when modeling a nonsectioned circuit with a single starting and stopping point. This is NULL when ISSECTIONED is True. The default is NULL.
STOPLOCATIONSOURCEID
Stop location source ID
The source ID of the feature or object that is associated with the stopping point for the circuit. This is used when modeling a nonsectioned circuit with a single starting and stopping point. This is NULL when ISSECTIONED is True. The default is NULL.
STOPLOCATIONID
Stop location ID
The global ID of the feature or object that is associated with the stopping point for the circuit. This is used when modeling a nonsectioned circuit with a single starting and stopping point. This is NULL when ISSECTIONED is True. The default is NULL.
STOPLOCATIONFIRSTUNIT
Stop location first unit
The first unit of the group associated with the stop location for the circuit (for example, equipment unit ID). This is used when modeling a nonsectioned circuit with a single starting and stopping point. This is NULL when ISSECTIONED is True. The default is NULL.
STOPLOCATIONLASTUNIT
Stop location last unit
The last unit of the group associated with the stop location for the circuit. This is used with the STOPLOCATIONFIRSTUNIT attribute to define the number of units that are grouped in the edge object and is used when modeling a nonsectioned circuit with a single starting and stopping point. This is NULL when ISSECTIONED is True. The default is NULL.
ISSECTIONED
Is sectioned
Specifies whether the circuit is modeled with or without sections. The default is False.
CIRCUITTYPE
Circuit type
Specifies whether the circuit is a physical circuit or a virtual circuit. A circuit is considered virtual when it contains one or more sections in which the SECTIONTYPE value is Virtual. The default is Physical.
ERRORMESSAGE
Error message
Specifies the error returned by the verify operation when a circuit fails to verify and is marked with a STATUS of Invalid. The default is NULL.
CONFLICTCONTAINERSTATE
Conflict container state
Specifies whether the circuit or its related sections or subcircuits have changed since the last reconcile operation. All circuits are conflict containers.
UPPERNAME
Upper name
The upper case name of the circuit.
GLOBALID
Global ID
The global ID of the row in the table. This value is referenced by the CircuitSection table as the CIRCUITID value, and the Subcircuit table as the PROVIDERID value where applicable.
The CircuitSection table stores information about the following:
  • The information that composes a section in a circuit.
  • The relationship with the circuit in which the section record participates.
  • Information about the features or objects that define the section record.
The CircuitSection table has the following attributes:
Field name
Field alias
OBJECTID
Object ID
CIRCUITID
Circuit ID
The global ID of the circuit in which the section participates.
Tip:
The CircuitSection table can be ordered by the CIRCUITID field to group all sections belonging to a single circuit.
SECTIONID
Section ID
The ID for the section in the circuit.
The source ID of the feature or object that is associated with the starting point for the circuit section. When the circuit section is associated with a subcircuit, this references the Subcircuit table alias. The default is NULL.
STARTLOCATIONID
Start location ID
The global ID of the feature or object that is associated with the starting point for the circuit section. When the circuit section is associated with a subcircuit, this references the GLOBALID of the subcircuit. The default is NULL.
The first unit of the group associated with the start location (for example, equipment unit ID) in the circuit section. When the circuit section is associated with a subcircuit, the value is NULL. The default is NULL.
The last unit of the group associated with the start location for the circuit section. This is used with the STARTLOCATIONFIRSTUNIT attribute to define the number of units that are grouped in the edge object for the circuit section. When the circuit section is associated with a subcircuit, the value is NULL. The default is NULL.
The source ID of the feature or object that is associated with the stopping point for the circuit section. When the circuit section is associated with a subcircuit, the value is NULL. The default is NULL.
STOPLOCATIONID
Stop location ID
The global ID of the feature or object that is associated with the stopping point for the circuit section. When the circuit section is associated with a subcircuit, the value is NULL. The default is NULL.
The first unit of the group associated with the stop location (for example, equipment unit ID) in the circuit section. When the circuit section is associated with a subcircuit, the value is NULL. The default is NULL.
The last unit of the group associated with the stop location for the circuit section. This is used with the STOPLOCATIONFIRSTUNIT attribute to define the number of units that are grouped in the edge object for the circuit section. When the circuit section is associated with a subcircuit, the value is NULL. The default is NULL.
ROLE
Role
Specifies the role of the record in the circuit. This is used to identify the start, end, and midspan sections of a circuit. This system-maintained field is derived from the SECTIONORDER field in the Circuit table. The default is Start and End. The values are as follows:
  • Start and End
  • Start
  • End
  • Midspan
SECTIONTYPE
Section type
Specifies whether the circuit section is physical or virtual. The default is Physical.
GLOBALID
Global ID
Subcircuit table
The Subcircuit table stores information about the following:
  • The name of the subcircuit.
  • The name of the provider circuit from which the subcircuit originates.
  • The name of the circuit which consumes the subcircuit.
The Subcircuit table has the following attributes:
Field name
Field alias
OBJECTID
Object ID
NAME
Name
PROVIDERID
Provider ID
The global ID of the circuit in the Circuit table from which the subcircuit originates.
CONSUMERID
Consumer ID
The global ID of the circuit in the Circuit table that consumes the subcircuit.
UPPERNAME
Upper name
The upper case name of the subcircuit.
GLOBALID
Global ID
