Add Telecom Domain Network (Utility Network Tools)
Summary
Adds a telecom domain network to a utility network.
Use the Add Domain Network tool to add a traditional domain network.
Learn more about how to add a domain network
Usage
  • The network topology must be disabled.
  • The Input Utility Network parameter value must reference a Utility Network Version value of 8 or later.
  • When working with an enterprise geodatabase, the following are requirements:
    • The Input Utility Network parameter value must be from a database connection established as the database utility network owner.
    • The connected ArcGIS Enterprise portal account must be the portal utility network owner.
    • This tool must be connected to the default version to run.
      • All other sessions connected to the default version are blocked from running validate or enable operations during the enable operation.
Parameters
Label Explanation Data type
The utility network to which the telecom domain network will be added.
Utility Network; Utility Network Layer
Domain Network Name
The name of the new telecom domain network. The domain network name will prefix the feature class names that are created. For example, a domain named Telco would include a feature class named TelcoJunction.
String
Domain Network Alias Name
(Optional)
The alias name of the telecom domain network. An alias can be used to provide a more descriptive name to the domain network.
String
Derived output
Updated Utility Network
The updated utility network.
Utility Network
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
