Add Domain Network (Utility Network Tools)
Summary
Adds a traditional domain network to a utility network.
Use the Add Telecom Domain Network tool to add a telecom domain network.
Learn more about how to add a domain network
Usage
  • The network topology must be disabled.
  • When working with an enterprise geodatabase, the following are requirements:
    • The Input Utility Network parameter value must be from a database connection established as the database utility network owner.
    • The connected ArcGIS Enterprise portal account must be the portal utility network owner.
    • This tool must be connected to the default version to run.
      • All other sessions connected to the default version are blocked from running validate or enable operations during the enable operation.
Parameters
Label Explanation Data type
The utility network to which the domain network will be added.
Utility Network; Utility Network Layer
Domain Network Name
The name of the new traditional domain network. The domain network name will prefix the feature class names that are created. For example, a domain named ElectricDistribution would include a feature class named ElectricDistributionJunction.
String
Tier Definition
Specifies the tier definition for the new traditional domain network.
  • Hierarchical—The tier will be defined as hierarchical. In hierarchical domain networks, tiers are nested within one another, so features existing in subnetworks for a lower tier naturally participate in all higher tiers. For example, in a gas network, a valve isolation zone exists in a pressure zone, which in turn exists in a system zone. A feature in the isolation zone also exists in the pressure zone and in the system zone.
  • Partitioned—The tier will be defined as partitioned. Features in partitioned domain networks only exist in one tier. The relationship between tiers is ordered and linear. Features can exist in one or multiple subnetworks in one tier.
String
Subnetwork Controller Type
Specifies the subnetwork controller type for the new traditional domain network.
  • Subnetwork source—The subnetwork controller type will be a set of sources. A source is an origin of the delivered resource. For example, in an electric system, sources of electricity are power generating stations and substations.
  • Subnetwork sink—The subnetwork controller type will be a set of sinks. A sink is the destination of the gathered resource.
String
Domain Network Alias Name
(Optional)
The alias name of the domain network. This optional parameter is used to provide a more descriptive name for the domain network.
String
Derived output
Updated Utility Network
The updated utility network.
Utility Network
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
