Set Terminal Configuration (Utility Network Tools)
Summary
Assigns a terminal configuration to an asset type in a utility network.
Once a terminal configuration has been established, you can use this tool to set the terminal configuration for a utility network asset type of a device feature class or junction object table. When a terminal configuration is assigned to an asset type, a feature created with that asset type includes terminals. More specifically, the feature includes the terminals specified for the terminal configuration.
To understand which underlying terminals are provided for each asset type, review the Terminal Configuration section on the Network Properties dialog box of the utility network layer properties.
Caution:
The default terminal configuration for all features is Single terminal. Assigning a terminal configuration to an asset type is permanent and cannot be changed after the network topology is enabled for the first time. This applies even if the network topology is in a disabled state.
Usage
A terminal configuration can be assigned to more than one asset type, but an asset type can only be assigned one terminal configuration.
You can use this tool with the Add Terminal Configuration tool, which adds a new terminal configuration to a utility network.
If an asset type has not been assigned a user-defined terminal configuration, the default terminal configuration is a single terminal.
The network topology must be disabled.
When working with an enterprise geodatabase, the connected ArcGIS Enterprise portal account must be the portal utility network owner.
When working with an enterprise geodatabase, this tool must be connected to the default version to run.
When working with an enterprise geodatabase, the Input Utility Network parameter value must be from a database connection established as the database utility network owner.
Parameters
| Label | Explanation | Data type |
Input Utility Network |
The utility network containing the terminal configuration that will be assigned to a specific asset type. |
Utility Network; Utility Network Layer |
Domain Network |
The traditional domain network to which the asset type belongs. |
String |
Input Table |
The utility network feature class or table to which the asset type belongs. |
String |
Asset Group |
The asset group to which the asset type belongs. |
String |
Asset Type |
The asset type that will receive the terminal configuration. |
String |
Terminal Configuration |
The terminal configuration that will be assigned to the asset type. |
String |
Derived output
Updated Utility Network |
The updated utility network |
Utility Network |
Environments
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
