Add Trace Configuration (Utility Network Tools)
Summary
Creates a named trace configuration in the utility network.
Named trace configurations allow you to configure and store the properties of complex traces for reuse and sharing. Named trace configurations created in a utility network can be used in ArcGIS Pro with the Trace tool or by using the Named Configurations tab in the Trace pane. When working in an enterprise deployment, named trace configurations can also be shared through a web map and used by web and field apps.
Usage
The Input Utility Network parameter value must be version 5 or later.
When working with an enterprise geodatabase, the input utility network must be from a utility network service.
The connected portal account is set as the creator of the named trace configuration. Operating system authentication is used to store the creator of a named trace configuration when working with a utility network in a single-user deployment.
License:
The active portal account must be assigned a license with the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
Parameters
| Label | Explanation | Data type |
Input Utility Network |
The utility network that will contain the new named trace configuration. |
Utility Network; Utility Network Layer |
Trace Configuration Name |
The name of the named trace configuration. |
String |
Trace Type |
Specifies the type of trace that will be used.
String |
Description (Optional) |
The description of the named trace configuration. |
String |
Tags (Optional) |
A set of tags used to identify the named trace configuration. The tags can be used in search and indexing. |
String |
Domain Network (Optional) |
The name of the tier in a traditional domain network where the trace will be run. This parameter is required when running the subnetwork, subnetwork controllers, upstream, downstream, and circuit trace types |
String |
Tier (Optional) |
The name of the tier where the trace will start. This parameter is required when running the subnetwork, subnetwork controllers, upstream, and downstream trace types. |
String |
Target Tier (Optional) |
The name of the target tier in a traditional domain network to which the input tier will flow in a directional trace. If this parameter is not specified for upstream and downstream traces, those traces will stop when they reach the boundary of the starting subnetwork. This parameter can be used to allow these traces to continue either farther up or farther down the hierarchy. |
String |
Subnetwork Name (Optional) |
The name of the subnetwork in a traditional domain network where the trace will be run. This parameter can be used when running a subnetwork trace type. If a subnetwork name is specified, starting points are not required. When the subnetworks table contains 10,000 or more records for a tier, the parameter's choice list is not populated and an empty field is provided for the subnetwork name. |
String |
Shortest Path Network Attribute Name (Optional) |
The network attribute that will be used to calculate the shortest path using the path or shortest path trace type. The shortest path is calculated using a numeric network attribute such as shape length. Cost- and distance-based paths can both be achieved. This parameter is optional for a path trace but is required when running a shortest path trace. |
String |
Include Containers (Optional) |
Specifies whether the container features will be included in the trace results.
Boolean |
Include Content (Optional) |
Specifies whether the trace will return content in container features in the results.
Boolean |
Include Structures (Optional) |
Specifies whether structure features and objects will be included in the trace results.
Boolean |
Include Barrier Features (Optional) |
Specifies whether the traversability barrier features will be included in the trace results. Traversability barriers are optional even if they have been preset in the subnetwork definition. This parameter does not apply to device features with terminals.
Boolean |
Validate Consistency (Optional) |
Specifies whether an error will be returned if dirty areas are encountered for any of the returned features. This is the only way to guarantee a trace is passing through features with consistent status in the network. To remove dirty areas, validate the network topology.
Boolean |
Condition Barriers (Optional) |
Sets a traversability barrier condition on features based on a comparison to a network attribute or check for a category string. A condition barrier uses a network attribute or network category, an operator and a type, and an attribute value. For example, stop a trace when a feature has the Learn more about using multiple conditional expressions Value table columns:
Value Table |
Function Barriers (Optional) |
Sets a traversability barrier on features based on a function. Function barriers can be used to do such things as restrict how far the trace travels from the starting point, or set a maximum value to stop a trace. For example, the length of each line traveled is added to the total distance traveled so far. When the total length traveled reaches the value specified, the trace stops. Value table columns:
Value Table |
Apply Traversability To (Optional) |
Specifies whether traversability will be applied to junctions, edges, or both. For example, if a condition barrier is defined to stop the trace if Device Status is equal to Open and traversability scope is set to edges only, the trace will not stop—even if it encounters an open device—because Device Status is only applicable to junctions. In other words, this parameter indicates to the trace whether to ignore junctions, edges, or both.
String |
Filter Barriers (Optional) |
Specifies when a trace will stop for a specific category or network attribute. For example, stop a trace at features that have a life cycle status attribute that is equal to a certain value. This parameter is used to set a terminator based on a value of a network attribute that is defined in the system. If you're using more than one attribute, you can use the Combine Using option to define an And or an Or condition. Learn more about using multiple conditional expressions Value table columns:
Value Table |
Filter Function Barriers (Optional) |
Filters the results of the trace for a specific category. Value table columns:
Value Table |
Apply Filter To (Optional) |
Specifies whether the filter for a specific category will be applied to junctions, edges, or both. For example, if a filter barrier is defined to stop the trace if Device Status is equal to Open and traversability scope is set to edges only, the trace will not stop—even if the trace encounters an open device—because Device Status is only applicable to junctions. In other words, this parameter indicates to the trace whether to ignore junctions, edges, or both.
String |
Filter by bitset network attribute (Optional) |
The name of the network attribute that will be used to filter by bitset. This parameter is only applicable to upstream, downstream, and loops trace types. This parameter can be used to add special logic during a trace so the trace more closely reflects real-world scenarios. For example, for a loops trace, the Phases current network attribute can determine if the loop is a true electrical loop (the same phase is energized all around the loop, that is, A) and return only real electrical loops for the trace results. An example for an upstream trace is when tracing an electric distribution network, specify a Phases current network attribute, and the trace results will only include valid paths that are specified in the network attribute, not all paths. |
String |
Filter by nearest (Optional) |
Specifies whether the k-nearest neighbors algorithm will be used to return a number of features of a certain type within a given distance. You can provide a count and a cost as well as a collection of categories, an asset type, or both.
Boolean |
Count (Optional) |
The number of features that will be returned when Filter by nearest is checked. |
Long |
Cost Network Attribute (Optional) |
The numeric network attribute that will be used to calculate nearness, cost, or distance when Filter by nearest is checked—for example, shape length. |
String |
Nearest Categories (Optional) |
The category or categories that will be returned when Filter by nearest is checked—for example, protective. |
String |
Nearest Asset Groups/Types (Optional) |
The asset groups and asset types that will be returned when Filter by nearest is checked—for example, ElectricDistributionDevice/Transformer/Step Down. |
String |
Functions (Optional) |
The calculation function or functions that will be applied to the trace results. Value table columns:
Value Table |
Propagators (Optional) |
Specifies the network attributes to propagate as well as how that propagation will occur during a trace. Propagated class attributes denote the key values on subnetwork controllers that are disseminated to the rest of the features in the subnetwork. For example, in an electric distribution model, you can propagate the phase value. In a telecom domain network, you can propagate wavelengths values from features defined as circuit locations. Note:This parameter is only available in Python. Value table columns:
Value Table |
Output Asset Types (Optional) |
Filters the output asset types to be included in the results—for example, only return overhead transformers. |
String |
Output Conditions (Optional) |
The types of features that will be returned based on a network attribute or category. For example, in a trace configured to filter out everything but Tap features, any traced features that do not have the Tap category assigned to them will not be included in the results. Any traced features that do will be returned in the result selection set. Learn more about using multiple conditional expressions Value table columns:
Value Table |
Include Isolated Features (Optional) |
Specifies whether isolated features will be included in the trace results. This parameter is only used when running an isolation trace.
Boolean |
Ignore Barriers At Starting Points (Optional) |
Specifies whether dynamic barriers in the trace configuration will be ignored for starting points. This may be useful when performing an upstream protective device trace using the discovered protective devices (barriers) as starting points to find subsequent upstream protective devices.
Boolean |
Include up to First Spatial Container (Optional) |
Specifies whether the containers returned will be limited to those encountered up to, and including, the first spatial container for each network element in the trace results. If no spatial containers are encountered but nonspatial containers are present for a given network element, all nonspatial containers will be included in the results. This parameter is only enabled when
Boolean |
Result Types (Optional) |
Specifies the type of results that will be returned by the trace.
String |
Allow Indeterminate Flow (Optional) |
Specifies whether features with indeterminate flow will be traced. This parameter is only applicable when running an upstream, downstream, or isolation trace.
Boolean |
Validate Locatability (Optional) |
Specifies whether an error will be returned during a trace if nonspatial junction or edge objects are encountered without the necessary connectivity, containment, or attachment association in their association hierarchy. This parameter ensures that nonspatial objects returned by a trace operation can be located through an association with features or other locatable objects.
Boolean |
Use Digitized Direction (Optional) |
Specifies whether upstream and downstream trace operations will determine flow direction using the digitized direction of the line, the From and To global ID of the edge object in the association, and the Note:For enterprise geodatabases, this parameter requires ArcGIS Enterprise 11.3 or later.
Boolean |
Synthesize Geometries (Optional) |
Specifies whether geometries will be inferred and created (synthesized) for associations and edge objects returned as part of a trace operation. This parameter is only applicable to the aggregated geometry result type. Note:For enterprise geodatabases, this parameter requires ArcGIS Enterprise 11.3 or later.
Boolean |
Num Paths (Optional) |
The maximum number of paths that will be returned between a given set of starting points and stopping points in a Path trace. The default is 2. This parameter is only active when the Trace Type parameter is set to Path. Note:For enterprise geodatabases, this parameter requires ArcGIS Enterprise 12.1 or later. |
Long |
Max Hops (Optional) |
The maximum number of hops between edges allowed in the path, excluding the starting point. All edges and junction-junction connectivity associations are evaluated as having a fixed unit length of 1 on traversal. The default is 100. This parameter is only active when the Trace Type parameter is set to Path. Note:For enterprise geodatabases, this parameter requires ArcGIS Enterprise 12.1 or later. |
Long |
Circuit Name (Optional) |
The name of the circuit in a telecom domain network where the circuit trace will be run. Note:For enterprise geodatabases, this parameter requires ArcGIS Enterprise 12.0 or later. |
String |
Infer Connectivity (Optional) |
Specifies whether the path trace will use connectivity inference to traverse containment associations and find a path between the specified starting and stopping location. This parameter is supported with the path trace in telecom domain networks and enables paths to be discovered between sections when connectivity information is not explicitly available. For more information, see Infer Connectivity.
Boolean |
Derived output
Output Utility Network |
The updated utility network. |
Utility Network |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
