Repair Network Topology (Utility Network Tools)
Summary
Verifies and repairs inconsistencies identified in the network topology system tables.
The Repair Network Topology tool is used to check and perform repairs for consistency in a network topology and create an output log file containing the issues that were discovered and repaired. This tool can be used in conjunction with the Verify Network Topology tool to perform verification and review results before a repair is run.
Usage
The network topology must be enabled.
When working with an enterprise geodatabase, the database connection must be from a branch versioned workspace.
When working with an enterprise geodatabase, the Input Utility Network parameter value must be from a database connection established as the database utility network owner.
When working with an enterprise geodatabase, the connected ArcGIS Enterprise portal account must be the portal utility network owner.
Parameters
| Label | Explanation | Data type |
Input Utility Network |
The utility network that will be repaired. |
Utility Network; Utility Network Layer |
Output Log File (Optional) |
The folder location and name of the file containing the discovered issues. |
File |
Derived output
Output Utility Network |
The repaired utility network. |
Utility Network |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
