Verify Network Topology (Utility Network Tools)
Summary
Verifies the network topology system tables and logs inconsistencies to an output log file.
The Verify Network Topology tool is used to check the consistency of a network topology and create an output log file containing the issues discovered. This tool can be used in conjunction with the Repair Network Topology tool.
Usage
  • The network topology must be enabled.
  • When working with an enterprise geodatabase, the database connection must be from a branch versioned workspace.
  • When working with an enterprise geodatabase, the Input Utility Network parameter value must be from a database connection established as the database utility network owner.
  • When working with an enterprise geodatabase, the connected ArcGIS Enterprise portal account must be the portal utility network owner.
Parameters
Label Explanation Data type
The utility network that will be verified for consistency.
Utility Network; Utility Network Layer
Output Log File
(Optional)
The output log file containing the discovered issues.
File
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
