Delete Rule (Utility Network Tools)
Summary
Permanently deletes a rule from a utility network.
Caution should be taken when deleting rules that support existing features or objects in a utility network. Existing network features that rely on deleted rules are marked with errors when the network topology is re-enabled to indicate there is no network rule to support the relationship.
Usage
  • When working with an enterprise geodatabase, the connected ArcGIS Enterprise portal account must be the portal utility network owner.
  • The network topology must be disabled.
  • When working with an enterprise geodatabase, the Input Utility Network parameter value must be from a database connection established as the database utility network owner.
Parameters
Label Explanation Data type
The utility network for which the rule will be removed.
Utility Network; Utility Network Layer
Rule Type
Specifies the type of rule that will be deleted.
  • All—All rules will be deleted.
  • Junction-junction connectivity—A junction-junction connectivity association rule will be deleted.
  • Containment—A containment association rule will be deleted.
  • Structural attachment—A structural attachment association rule will be deleted.
  • Junction-edge connectivity—A junction-edge connectivity rule will be deleted.
  • Edge-junction-edge connectivity—An edge-junction-edge connectivity rule will be deleted.
String
Rules
Specifies the rules that will be removed, including the rule ID and the description of the rule.
To find the rule ID, browse the Rules section on the Network Properties tab on the Layer Properties dialog box. For more information, see View network rules.
String
Derived output
Updated Utility Network
The updated utility network.
Utility Network
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
