Delete Color Scheme (Utility Network Tools)
Summary
Deletes a color scheme from a telecom domain network. Each color scheme includes a hierarchical definition with multiple levels in which each level has its own labels, capacities, and delimiters.
Usage
The Input Utility Network parameter value must reference a utility network version 8 or later.
The utility network dataset provided for the Input Utility Network parameter must include a telecom domain network.
The following requirements must be met when working with an enterprise geodatabase:
The Input Utility Network parameter value must be from a database connection established as the database utility network owner.
The connected ArcGIS Enterprise portal account must be the portal utility network owner.
License:
The active portal account must be assigned a license with the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
Parameters
| Label | Explanation | Data type |
Input Utility Network |
The input utility network containing the color scheme that will be deleted. |
Utility Network; Utility Network Layer |
Domain Network |
The telecom domain network containing the color scheme that will be deleted. |
String |
Color Scheme Name |
The name of the color scheme that will be deleted. |
String |
Derived output
Output Utility Network |
The updated utility network. |
Utility Network |
Environments
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
