Delete Network Category (Utility Network Tools)
Summary
Deletes a network category in a utility network.
Usage
  • A network category cannot be deleted if it is assigned to an asset type. A network category can be unassigned using the Set Network Category tool.
  • When working with an enterprise geodatabase, the connected ArcGIS Enterprise portal account must be the portal utility network owner.
  • The network topology must be disabled.
  • When working with an enterprise geodatabase, this tool must be connected to the default version to run.
Parameters
Label Explanation Data type
Input Utility Network
The utility network that contains the network category to be deleted.
Utility Network; Utility Network Layer
Category Name
The name of the network category to delete.
String
Derived output
Updated Utility Network
The updated utility network.
Utility Network
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
