Set Network Category (Utility Network Tools)
Summary
Assigns a network category to a feature class or table at the asset type level to be used during tracing operations.
Categories are defined on asset types to constrain the beginning and end of several analytical traces.
Learn more about network categories
Learn more about how to set or modify a network category assignment
Usage
An asset type can participate in one or more categories. For example, a fuse asset group can be in both a disconnect and a protective category. A fiber asset type can be assigned both as a unit container and as unit identifiable.
This tool can be used with the Add Network Category tool, which is used to add a new network category to the utility network.
The network topology must be disabled.
The following requirements must be met when working with an enterprise geodatabase:
The connected ArcGIS Enterprise portal account must be the portal utility network owner.
The Input Utility Network parameter value must be from a database connection established as the database utility network owner.
This tool must be connected to the default version to run.
- All other sessions connected to the default version are blocked from running validate or enable operations during the enable operation.
Parameters
| Label | Explanation | Data type |
Input Utility Network |
The utility network that contains the network category. |
Utility Network; Utility Network Layer |
Domain Network |
The domain network in the utility network that contains the network category. |
String |
Input Table |
The utility network feature class or table to which the asset type belongs. |
String |
Asset Group |
The asset group to which the asset type belongs. |
String |
Asset Type |
The asset type that will be used to alter the category configuration. |
String |
Categories (Optional) |
The categories that will be assigned to the asset type. The categories that are specified for this parameter will replace the current categories that are assigned to the asset type. To unassign a network category from an asset type, do not specify a category for this parameter. Note:The Subnetwork Controller system-provided network category is only available with traditional domain networks for asset types in the device feature class and junction object table. In a traditional domain network with a partitioned tier definition, the selected asset type must also have a directional terminal configuration assigned with a minimum of one upstream and one downstream terminal. |
String |
Derived output
Updated Utility Network |
The updated utility network. |
Utility Network |
Environments
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
