Set Edge Connectivity (Utility Network Tools)
Summary
Defines how features will connect to a line or edge object of a given asset type.
Connectivity may be established with lines and edge objects at two locations: an endpoint and a midspan vertex. Each asset type in the domain network is set with a default edge connectivity setting.
Learn more about how to set edge connectivity for features
Usage
  • The network topology must be disabled.
  • The following requirements must be met when working with an enterprise geodatabase:
    • The Input Utility Network parameter value must be from a database connection established as the database utility network owner.
    • The connected ArcGIS Enterprise portal account must be the portal utility network owner.
    • This tool must be connected to the default version to run.
      • All other sessions connected to the default version are blocked from running validate or enable operations during the enable operation.
Parameters
Label Explanation Data type
The utility network that contains the asset type with the edge connectivity to set.
Utility Network; Utility Network Layer
Domain Network
The domain network that contains the asset type with the edge connectivity to set.
String
Input Table
The name of the input feature class or table that contains the asset type with the edge connectivity to set.
String
Asset Group
The asset group that contains the asset type with the edge connectivity to set.
String
Asset Type
The asset type that requires the edge connectivity to set.
String
Edge Connectivity
Specifies the edge connectivity type that will be assigned to the asset type.
  • Any vertex—Features will connect anywhere along the edge including end vertices.
  • End vertex—Features will only connect to the end vertex of an edge.
String
Derived output
Updated Utility Network
The updated utility network.
Utility Network
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
