Add Color Set (Utility Network Tools)
Summary
Adds a color set to define the colors that may be reused across color schemes in a telecom domain network. Color sets provide a standardized color library which can be consumed by color schemes in your network using the Add Color Scheme tool.
Usage
  • The Input Utility Network parameter value must reference a utility network version 8 or later.
  • The utility network dataset provided for the Input Utility Network parameter must include a telecom domain network.
  • The Color Set Name parameter value must be unique in the domain network and may not exceed 256 characters.
  • The Color Codes parameter's Name and Label property values may not exceed 256 characters.
  • The Color Codes parameter's HexCode property value must contain a 6-digit hex triplet, for example FF0000. Multiple hex codes can be provided using a comma delimited list.
  • The following requirements must be met when working with an enterprise geodatabase:
Learn more about adding a color set
Parameters
Label Explanation Data type
The input utility network where the color set will be added.
Utility Network; Utility Network Layer
Domain Network
The telecom domain network where the color set will be added.
String
Color Set Name
The name of the color set that will be added. The name must be unique in the utility network.
String
Color Codes
Properties that describe the attributes for each color code in the color set.
Value table columns:
  • Name—The name for the color code. This is used to describe the color set for use in a color scheme.
  • Label—The label used to display the color code in a color scheme.
  • HexCode—The six digit alphanumeric hex color code used to defined the color code in the set, for example, FF0000. Multiple hex codes can be provided using a comma delimited list.
Value Table
Derived output
Output Utility Network
The updated utility network.
Utility Network
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
