QuickCapture capability in ArcGIS
ArcGIS Experience Builder and Survey123 Mobile now support the big-button data capture experience by using ArcGIS QuickCapture projects in the following ways:
  • Add a QuickCapture widget in Experience Builder so that users can enter data using big-button capture in a web browser.
  • Browse to and launch a QuickCapture project by opening content directly in Survey123 Mobile.
  • Launch a downloaded QuickCapture project from a link inside a survey in Survey123 Mobile, and stay in the single app, using either a QuickCapture or custom URL scheme link.
Not all existing QuickCapture features are supported in Experience Builder and Survey123 Mobile. When features are not supported, the feature will typically be absent from the app with the following exceptions:
  • If the user taps a project button that targets a line or polygon layer, they will see a dialog box that explains that these button types are not supported.
  • If the project uses unsupported QuickCapture variables, field values will remain empty.
The following are the statuses used in this documentation:
  • Available—The functionality is available for use now, some limitations may apply, but these are described in the specific documentation
  • In development—Work is in progress on the functionality and it will be available in the next release or two.
  • Planned—Work on the functionality is not in progress, but it is planned for a future release.
  • Not planned—The functionality is not planned for inclusion. It may be superseded by different behavior or technology, or is not applicable.
The following table lists the status of functionality:
Functionality area
Behavior
Status in Experience Builder
Status in Survey123 Mobile
Button types
Point capture
Available
Available
Line or polygon capture
Available (in map sketch mode)
Planned
Link buttons
Planned
Available
Exclusive groups
Planned
Planned
Media
Photos optional (1-5)—optional
Planned
Available
Photos required (1-5)—required
Planned
Available
Automatic photos
Planned
Planned
Video
Not planned
Planned
Read and write EXIF tags
Planned
Planned
Project user input variable
Label
Available
Available
Input type single-line text
Available
Available
Input type multiline text
Available
Available
Input type choice list, list in project
Available
Available
Input type choice list, list from feature service domain
Planned
Planned
Input type choice list, dynamic
Planned
Planned
Apply hint
Available
Available
Apply an input mask
Available
Available
Required
Available
Available
Barcode scanner
Not planned
Planned
Button user input variable
Label
Available
Available
Available
Available
Input type multi-line text
Available
Available
Input type date time
Planned
Planned
Available
Available
Input type choice list, from feature service domain
Planned
Planned
Planned
Planned
Apply hint
Available
Available
Apply an input mask
Available
Available
Required
Available
Available
Barcode scanner
Not planned
Planned
Show the user input dialog box at the start or end of capture
Planned
Planned
Device variables
Latitude
Available
Available
Longitude
Available
Available
Altitude
Available
Available
CaptureTime
Available
Available
All other device variables
Planned
Planned
Data sending and recovery
Autosend
Available
Planned
Data recovery
Not planned
Planned
Maps
Online web map
Available
Available
Offline packages
Not planned
Planned
Map tools
Not planned
Planned
Edit last captured record
Delete record
Planned
Planned
Update location
Not planned
Planned
Use a high-accuracy receiver
Internal position source
Available
Available
External GNSS receiver
Not planned
Available
Bluetooth
Not planned
Available
Network
Not planned
Planned
Record NMEA file
Not planned
Planned
Play NMEA file
Not planned
Planned
Platform capabilities
ArcGIS Arcade expressions
Planned
Planned
Oriented imagery
Not planned
Planned
Location sharing
Not planned
Planned
Organizational settings
Automatic project updates
Not planned
Planned
Autosend interval
Not planned
Planned
Integration
Webhooks
Not planned
Not planned
QuickCapture and custom URL scheme links
Planned
Planned
