What's new in ArcGIS for SharePoint
The 2026.2 update to ArcGIS for SharePoint includes the following:
  • Use the Add layer pane to import a shapefile, and create either a hosted feature layer or a SharePoint list.
  • You can now configure ArcGIS for SharePoint to store terms, either at the site level or the global term group level.
  • You can now delete a flow created for Geocoding, or extract EXIF data directly from SharePoint. For more information, see Extract EXIF data.
  • Edit map view is now called Map view, which honors item level permissions for SharePoint lists and document library items. This allows you, upon sign-in, to add a basemap from your ArcGIS organization.
If you have an idea for additional functionality or an enhancement for ArcGIS for SharePoint, you can share it at the ArcGIS Ideas site. You can also visit the ArcGIS for SharePoint Esri Community page to learn more.
