Organization survey and settings management
You can manage all surveys in an organization and organization-wide settings for Survey123 on the Organization page of the Survey123 website. This page is only available to organization administrators or users with a role that includes the Organization website privilege. To learn more about privileges, see Administrative privileges in ArcGIS Online or Administrative privileges in ArcGIS Enterprise.
Manage surveys
Surveys are managed by administrators in the same way as an owner would manage a survey. On the All surveys tab on the Organization page of the Survey123 website, you can see all surveys in your organization. As an administrator, you can do the following:
  • Filter surveys by organization member.
  • Update survey information, republish, or change sharing permissions for any survey.
  • Add report templates to any survey.
  • Change ownership of a survey from one organization member to another.
When changing the ownership of a survey, the ownership of linked content, printed reports, and exported data is not changed. If the survey was created from an existing feature layer, the ownership of the source feature layer item is not changed. Ownership of report templates and feature layers that were generated by Survey123 is changed. The Associated items table, shown during the change of ownership step, lists all associated items and indicates whether the ownership of each item is changed.
Organization settings
An organization administrator can configure settings that apply to all Survey123 users. On the Organization page of the Survey123 website, click the Settings tab to view or modify these settings.
These settings change the behavior of Survey123 for all users in your organization.
Organizational settings will only apply to public surveys if Allow anonymous access to your organization is enabled for your ArcGIS organization. For more information, see Configure security settings in ArcGIS Online or Configure security settings in ArcGIS Enterprise.
The following tables describe the organization settings:
General
Setting
Shared theme
Override the default app theme with the colors and logo in your organization's shared theme. For more information, see Shared theme in ArcGIS Online or Shared theme in ArcGIS Enterprise.
This setting is supported in Survey123 Connect and the Survey123 web designer.
Tutorials tab
Show the Tutorials tab in Survey123 Connect. The content on the Tutorials tab is regularly updated from online sources.
Community tab
Show the Community tab in Survey123 Connect. The content on the Community tab is regularly updated from online sources.
New surveys
Choose the templates and samples that are available to survey authors when creating a survey:
  • Organization templates—Templates shared in your organization. It allows administrators to specify the group whose form items are made available as templates for organization members.
  • Templates and samples from Esri—Templates for various uses and industries, and samples that demonstrate Survey123 features and design techniques.
  • Templates from the Survey123 community—Templates designed by Survey123 users and shared publicly. For more information, see the Survey123 Community page.
  • Surveys in my organization—Allow all organization members to see shared surveys created by all other organization members. Surveys that have not been shared with the organization or the organization member will not be shown.
Organization templates, Templates and samples from Esri, and Templates from the Survey123 community are supported in Survey123 Studio, Survey123 Connect, and the Survey123 web designer. Surveys in my organization is only supported in Survey123 Studio and Survey123 Connect.
Map
Setting
Map gallery
Select the group whose web maps will be shown in the map gallery of the field app and web app. The organization basemap gallery is the default. Basemaps with projections other than Web Mercator Auxiliary Sphere can be used in Survey123 Mobile and the web app.
In the Survey123 field app, all basemaps must use the Web Mercator Auxiliary Sphere projection.
Default map
Select the default map used in a survey. The survey owner can override this setting on a per-survey basis. The organization basemap is the default.
Surveys
Setting
Require update
Require users to update a survey if a newer version is available. Users cannot access the survey until it has been updated. The survey owner cannot override this setting.
This setting is supported in the Survey123 field app only.
Location sharing
Setting
Location sharing
Enable location sharing for users in your organization. Additionally, you can require it, meaning that users cannot turn it off in the field app and location sharing will always be on.
Data
Record tracks, the last known location, or both.
Tracks are uploaded every 10 minutes, and last known locations every 1 minute.
Map gallery
Select the group whose web maps will be shown in the map gallery in the location sharing map. The organization basemap gallery is the default. All basemaps used in the Survey123 field app must use the Web Mercator Auxiliary Sphere projection.
Default map
Select the default location sharing map.
Extensions
Setting
Enhanced camera features
Enhanced camera features can improve accuracy and performance when scanning barcodes and detecting faces in photos. For more information, see Machine learning.
Choose from the following options:
  • Let users decide in field app settings—This is the default. Users can enable and disable enhanced camera features in the field app by clicking Settings > Privacy and Security.
  • Enable enhanced camera features—Enable enhanced camera features by default for all users in the organization. When a user interacts with the setting in the field app, their choice takes precedence over this organization setting.
  • Disable enhanced camera features—Disable enhanced camera features for all users in the organization. The setting in the field app is also disabled.
Caution:
Enhanced camera features use Google ML Kit. When you enable enhanced camera features in the field app, usage statistics may be sent to Google to measure performance, debug, maintain and improve products, and detect misuse or abuse. Image processing happens entirely on the device and no images are sent to Google servers. For more information, see Google ML Kit Terms & Privacy on the Google developers website.
On iOS, barcode scanning and surveys that include the engine=vision property for smart redaction automatically use Apple built-in Vision APIs. These APIs may send analytics data to Apple. Analytics data may include details about hardware and operating system specifications, performance statistics, and data about how you use your devices and applications. You can review this information in the privacy and security settings on your iOS device. This information is used to help Apple improve and develop its products and services. None of the collected information identifies you personally. Personal data is not logged, is subject to privacy preserving techniques such as differential privacy, or is removed from any reports before being sent to Apple. For more information, see Device Analytics & Privacy and Data & Privacy on the Apple website.
Survey123 assistant
The Survey123 assistant uses generative AI to do the following:
  • Use a conversation to help you design a survey in the web designer.
  • Translate survey designs in the web designer or in Survey123 Connect.
For more information, see AI in Survey123.
AI analysis tools
Use AI analysis tools to improve efficiency and streamline workflows by using:
  • Image analysis
  • Text analysis
  • Audio transcription (beta)
Location sharing in your organization
This section describes functionality that is only available in the Survey123 field app. This functionality is not available in Survey123 Mobile.
Location sharing is an organization-wide capability that allows you to record where mobile workers are and where they have been. When you enable location sharing, licensed users in your organization can use the Survey123 field app to upload their locations to the location sharing layer. The tracks are secure in the location sharing layer—field workers only see their own tracks, and additional permissions are required to view the tracks of others. Once location sharing is enabled, administrators can use the Track Viewer web app to share the last known location and track data with other users in the organization by creating track views.
To learn more about enabling location sharing in your organization, see Enable location sharing in ArcGIS Online and Enable location sharing in ArcGIS Enterprise, or see the Deploy a location sharing solution with Survey123 implementation guide.
Once location sharing is enabled in the organization, an organization administrator can configure how location sharing will be used in the Survey123 field app, on the Settings tab of the Organization page of the Survey123 website. Sharing choices are listed in the table above.
If the device is offline, locations are stored locally until the device is online, and they will automatically be uploaded. If the user signs out while the device is offline, a message appears warning the user that unsent tracks will be deleted.
To learn more, see FAQ for survey creators and FAQ for submitters.
