Create the app
Available with an ArcGIS Topographic Mapping license.
Once the web map is shared to your portal, you can use it to create a web app.
Learn more about creating a web app from a web map
To create the Map Production System (MPS) web app from the web map you created and shared, complete the following steps:
  1. In your ArcGIS Enterprise portal, click the Content tab and find the web map that contains the AOI layers that you shared.
  2. Click the web map to open its Overview page.
  3. Click the Create app drop-down arrow and click Topographic Production.
    You may need to click the Show more drop-down arrow for Create app to appear.
    The Topographic Production System page appears.
    Tip:
    If you don't see the Topographic Production System page, ensure that the Topographic Production System app gallery is enabled on your organization's portal properties. You can use the ArcGIS Portal Directory (Sharing API) to insert "tpsEnabled":true in the Portal Configuration Properties parameter.
  4. Click the Choose button for Map Production System.
    The Create App - Map Production System dialog box appears.
  5. Provide a title, the tags, and a folder location for the app.
  6. Click CREATE APP.
    The Map Production System dialog box appears and you can configure the MPS app's settings.
The MPS web app is created after the settings are configured and appears as an item on your portal's Content tab. To access it from the item's Overview page, click View.
The first time the app is opened, its settings must be configured by someone with administrator privileges. This includes the type of map products the app can export and other properties, including its appearance.
