Configure general settings
Available with an ArcGIS Topographic Mapping license.
You can modify the appearance, title, and logo of the Topographic Production Manager (TPM) web app as a user with administrator privileges.
To configure the general settings, complete the following steps:
Access the TPM web app's settings.
Provide the text that you want to appear in the app's header in the Title and Subtitle text boxes.
Optionally, upload a logo or splash screen for the app.
The maximum size supported for the logo image file is 400x400 pixels and the default logo is available at
C:\Program Files\ArcGIS\Portal\apps\tps\images\. It maintains a 1:1 aspect ratio when the width or height values are changed.The splash screen image's width and height values cannot be modified, but they resize with the browser window. The default image is available at
C:\Program Files\ArcGIS\Portal\apps\tps\images\.The maximum size supported for the logo image file is 400x400 pixels and the default logo is available at
<Enterprise installation location>/portal/apps/tps/images/. It maintains a 1:1 aspect ratio when the width or height values are changed.The splash screen image's width and height values cannot be modified, but they resize with the browser window. The default image is available at
<Enterprise installation location>/portal/apps/tps/images/.Note:
If a custom logo or splash screen image is uploaded, it is saved as a public item by default in the TPM Files folder on the ArcGIS Enterprise portal. The name of the items start with the associated app's ID to support images for multiple apps on the same portal. When a new custom logo or splash screen image item for an instance of an app is uploaded, it overwrites the existing custom image item for that app.
The following image formats are supported:
PNG
JPG
JPEG
SVG
GIF
Optionally, click the Theme drop-down arrow and choose a preset theme for the app.
If an SVG formatted logo exists locally, the chosen theme's colors are applied to it. Custom formatted logos uploaded through the app are not impacted by the chosen theme.
Check the Always require login check box to require users to sign in to the portal even if the services used by the app are shared publicly.
Confirm that the Use portal-configured basemaps check box is checked to use basemaps from the associated portal.
These basemaps are part of a group configured for the basemap gallery.
Click Update to save the changes or click Close to close the dialog box.
The Topographic Production Manager dialog box closes and the TPM app opens with the settings you configured.
