Set up the Topographic Production Manager web app
Available with an ArcGIS Topographic Mapping license.
You can manage topographic production projects and jobs with the self-serve Topographic Production Manager (TPM) web app. This app uses the Topographic Production Service that is deployed when you publish a map as a web layer that contains feature data. The product data files for the ArcGIS Topographic Mapping server extension are required to set up the app. You'll need to copy the TPM app files from the product files to the Portal for ArcGIS app location.
After the service is deployed, the web layer is published, and the installed product files are copied to your server, you can configure your organization's ArcGIS Enterprise portal, prepare and share a web map in ArcGIS Pro, and create the TPM web app.
The following high-level steps describe how to set up the TPM web app:
  1. Create a web map in ArcGIS Pro.
  2. Share the web map from ArcGIS Pro.
  3. Create the TPM web app from the web map.
  4. Configure the app settings.
