Set up ArcGIS Urban
ArcGIS Urban is accessible with or without an ArcGIS Urban license:
Users without a license can access publicly shared urban models, plans, and projects in the read-only view (for example, stakeholders or the public).
Users with an ArcGIS Urban license can administer urban models and edit plans and projects (for example, urban planners or GIS professionals).
See the sections below to learn how to license ArcGIS Urban and how to create an urban model.
ArcGIS Urban is licensed under the Professional Plus user type. To learn more about different user types, see User types. Users with existing ArcGIS Urban add-on licenses can continue using them until their expiration date.
License ArcGIS Urban
An ArcGIS Urban license is required to administer an urban model and edit plans and projects. The ArcGIS Urban license is included in the Professional Plus user type. To learn more about user types and roles and how to manage them, see Manage members in the ArcGIS Enterprise help. To learn more about the Professional Plus user type, see the Professional Plus product page.
The accessibility of ArcGIS Urban workflows depends on the privileges that are associated with user roles. See Workflow accessibility to learn more.
Before June 2025, ArcGIS Urban was licensed through an add-on license. Add-on licenses issued before June 2025 remain valid until they expire.
Create an urban model
To create an urban model, verify that your user account includes an ArcGIS Urban license, and complete the steps below.
Sign in to your ArcGIS organization.
Go to the Content page in your organization, click the Create app button, and choose Urban.
ArcGIS Urban starts.
Choose the location of your urban model.
Type an address or the name of a place in the input field, and press the Enter key to confirm.
Use the handles in the map to adjust the model location.
The model location has the following implications:
It defines the initial map view when you open the urban model. You can change it later. See Configure general settings for details.
It optimizes the address search in Urban. You can only search for addresses that are within the model location extent.
It makes your urban model item in your organization searchable by location.
It limits the basemap you can choose for the model on the Select basemap dialog box. Only basemaps that intersect with the model extent can be used.
Select the basemap and coordinate system for the urban model.
The coordinate system of the basemap defines the type of the urban model: local or global. By default, a global urban model with the WGS 1984 Web Mercator coordinate system is created. When you select a basemap with a projected coordinate system, a local urban model is created. See the Understanding local and global urban models section below to learn more about the differences.
In a local urban model, certain functionality is not available. See the Understanding local and global urban models section below to learn more.
The urban model coordinate system cannot be changed after the model has been created.
Click the Select item button
.Select an item from the Select basemap dialog box.
Only items from your organization's basemap gallery can be selected. See the Configure map topic in the ArcGIS Enterprise documentation to learn more about configuring the basemap gallery.
Only items that intersect with the extent of the urban model can be selected. See Define content extent in the ArcGIS Enterprise documentation to learn how to set the extent of an item.
Click Select to close the dialog box.
If you selected a basemap with a projected coordinate system, check the check box to acknowledge the limitations of local urban models.
Select an elevation layer for the urban model. See Elevation layer to learn more.
.Select an item from the Select elevation layer dialog box.
The elevation layer must have the same coordinate system and tiling scheme as the basemap. See Configure a web elevation layer for more information on how to set up a tiling scheme for an elevation layer before publishing.
For global urban models in Web Mercator, the default elevation is used and the Select elevation layer section is not shown. You can configure the elevation layer after the urban model has been created. See Configure an elevation layer to learn more.
Expand the Template drop-down menu to select a template.
The template selected by default depends on your model location. See Work with urban model templates below for details.
You can select any available template.
If you choose a template other than the default selection, included indicator data may not work as expected because the indicators in the templates are tied to specific coordinate systems.
Optionally, click Import from feature layer to upload a parcels layer.
The parcels are converted to the coordinate system of the urban model if the coordinate systems don't match.
You can also upload parcels later. See Add parcels for details.
Optionally, click Import from feature layer again to upload zoning boundaries from a feature layer with defined symbology for each zoning type.
The zoning boundaries are converted to the coordinate system of the urban model if the coordinate systems don't match.
You can also upload zoning boundaries later. See Manage zoning for details.
Click Create Urban Model.
When the setup tool has finished creating the urban model, ArcGIS Urban starts automatically.
Closing the browser tab or refreshing the page cancels the initialization process. Keep the tab open while the urban model is created.
For more information and step-by-step instructions on how to prepare data using the data manager, see Prepare data.
Templates can include zoning types, overlay types, land-use types, space-use types, building types, project status types, metrics, indicators, and feedback categories.
When you create an urban model, you can choose a built-in template such as Empty, USA, or Default, or a regional template provided and maintained by Esri partners and distributors.
The following templates are currently available. The template selected by default depends on the model location:
United States: The built-in USA template is selected by default.
Norway: The Norway template is selected by default. This regional template is provided and maintained by an Esri partner. Included indicators are designed for the ETRS89 / UTM zone 32N (EPSG:25832) coordinate system.
All other locations: The built-in Default template is selected by default.
Empty (all locations): The built-in Empty template is always available and is never selected by default. Use this template to create an urban model without preconfigured data.
To learn more about templates provided by Esri partners and distributors and corresponding support contacts, see the Regional templates section below.
Regional templates
Regional templates are provided and maintained by Esri partners and distributors. These organizations are responsible for the content of their templates. If you have questions, contact the provider directly using the information in the following table:
| Region | Provider | Contact | Recommended coordinate system |
| Norway | Geodata AS | Support - Geodata | ETRS89 / UTM zone 32N (EPSG:25832) |
Depending on the coordinate system used, the urban model will be displayed in a local or a global scene in Urban.
For projected coordinate systems, the urban model is displayed in a local scene.
For WGS84, WebMercator, and CGCS2000, the urban model is displayed in a global scene.
See Viewing modes to learn about the technical differences between local and global scenes, and Supported coordinate systems for further information.
Before creating an urban model, consider the following:
If you have 3D base layers such as existing buildings, trees, reality mesh, elevation layer, and context layers stored in a projected coordinate system, it is recommended that you create a local urban model.
If you don't have 3D base layers and you want to use the out-of-the-box data in Urban, it is recommended that you create a global urban model in Web Mercator.
Geometries that you create or import in Urban are stored in the coordinate system of the urban model. On import, geometries are converted to the coordinate system of the urban model if the coordinate systems don't match.
When uploading 3D models for projects in an urban model in Web Mercator, the data is stored in WGS84 to avoid significant distortions and scale variations when editing.
Layers that are loaded in Urban—such as 3D base layers, context layers, and indicator layers—must match the coordinate system of the urban model, with the exception of noncached layers such as feature layers. Noncached layers can be added in any coordinate system, since they will be reprojected to the coordinate system of the urban model.
See Geometry projections to learn more about the impact of reprojecting geometries, and Data layers for further information on different types of data layers.
In local urban models and global urban models in CGCS2000, you cannot use certain functionality due to technical limitations. The following are not available:
Default 3D base layers configured in your organization
Default basemaps configured in your organization
Default elevation layer configured in your organization
Street-level imagery
In global urban models in WGS84, the following are not available:
