Add and edit parcels
The Edit parcels tool allows you to do the following:
In the development side panel, you can edit the following parcel data:
With the exception of adding parcels, you first have to select the parcels that you want to edit. This is described in the Select parcels selection below.
Add a parcel
To add a parcel by drawing its geometry, complete the following steps:
Open the plan editor.
Click the Development button
in the header to access development mode.Click the Edit parcels button
on the workflow toolbar, and from the Edit parcels tools in the header, click the Add button
.A drawing interface appears.
Click the map to draw the boundaries of the new parcel. Double-click when you are finished.
The OK button becomes available and the new parcel turns orange.
Parcels cannot overlap. Overlapping parts are automatically trimmed.
This tool supports snapping. To disable snapping temporarily, press the Ctrl key while drawing.
This tool supports editing constraints. Press the Tab key while drawing to input exact dimensions.
Click OK.
Click Done to close the Edit parcels tools.
Instead of drawing parcels manually, you can add them as a layer in the data manager or in the plan configuration. This allows you to import all parcels in a city from a hosted feature layer. See Add parcels and Configure a plan for details.
Select parcels
Click a single parcel to select it in the view. To select multiple parcels, press the Shift key while clicking the parcels or use one of the Advanced Selection tools. To deselect a parcel from a group selection, press the Alt key while clicking it in the scene view.
Use freehand selection
To select parcels using the Freehand selection advanced selection tool, complete the following steps:
Click the Advanced selection button
on the vertical toolbar between the view and the side panel.Click the Freehand selection button
on the blue header bar.Drag the pointer to draw freehand in the view.
Draw a line to select all parcels intersecting that line.
Draw a polygon to select all parcels intersecting that polygon.
Click Done to close the Freehand selection tool and continue working with the selected parcels.
Use rectangle selection
To select parcels using the Rectangle selection advanced selection tool, complete the following steps:
on the vertical toolbar between the view and the side panel.Click the Rectangle selection button
on the blue header bar.Drag the pointer to draw a rectangle.
Drag the pointer from right to left to select parcels that intersect the rectangle.
Drag the pointer from left to right to select parcels in the rectangle.
Click Done to close the Rectangle selection tool and continue working with the selected parcels.
Use select by feature
To select parcels using the Select by feature advanced selection tool, complete the following steps:
on the vertical toolbar between the view and the side panel.Click the Select by feature button
on the blue header bar.Select a polygon feature in the view to use to select the parcels.
Tip:
Distinguish overlapping polygons by clicking their edges. You can also use the options menu to turn off polygon layers that you don't want to use for selecting parcels.
Parcels that intersect with the selected polygon feature are selected.
Click Done to close the Select by feature tool and continue working with the selected parcels.
Merge parcels
To merge parcels, complete the following steps:
in the header to switch to development mode.Click the Edit parcels button
on the workflow toolbar.Select two adjacent parcels.
Click the Merge button
from the Edit parcels tools in the header.Click the blue merge button on the Merge selection dialog box to confirm the merge.
Split a parcel
To split a parcel, complete the following steps:
on the workflow toolbar.Select a parcel.
Click the Split button
from the Edit parcels tools in the header.Draw a polyline to split the parcel.
Click the OK button in the header.
The start and the end of the polyline must be outside the target parcel while viewing the parcel from above. Click the 2D button at the lower right of the view to do so.
Subtract path
Complete the following steps to divide a parcel using a defined path width. This workflow is useful for parcels that are spilt by a street or other geometries that cause a single parcel to appear in two pieces.
Click the Subtract path button
from the Edit parcels tools in the header.Define the width of the path on the blue header bar.
The width is the amount of space that will be left between each portion of your parcel after splitting.
Draw a path to subtract from the selected parcel.
Double-click to complete and click OK.
Split a parcel into a grid
Complete the following steps to split a parcel into a grid:
on the workflow toolbar.Select a large parcel.
Click the Grid button
from the Edit parcels tools in the header.Split the selection.
Square cells—Split into squared cells.
Honeycomb cells—Split into hexagonal cells.
Specify the grid cell size on the blue header bar.
As you type a cell size, the grid pattern preview changes accordingly in the view.
For performance reasons, the minimal grid cell size is restricted. It depends on the size of the study area.
Specify the grid cell orientation on the blue header bar.
As you edit the cell orientation, the grid pattern preview changes accordingly in the view.
Click OK.
The selected parcel is split into smaller parcels according to the specified grid configurations.
Retire parcels
You can delete parcels by retiring them. To retire a parcel, complete the following steps:
on the workflow toolbar.Select the parcel you want to retire.
Click the Retire button
from the Edit parcels tools in the header.A confirmation message appears.
Click Retire to delete the parcel.
Edit parcel edges
You can calculate the orientation and street adjacency attributes of parcel edges in ArcGIS CityEngine or manually define them while editing a plan. These attributes are used when developing a parcel—for example, when adding tiers and setbacks or skyplanes. To edit them while editing a plan, complete the following steps:
on the workflow toolbar.Select the parcel you want to edit the edges.
Click the Edge orientation button
from the Edit parcels tools in the header.The Editing parcel edges options appear at the top of the view.
Click the edge you want to assign an orientation to, or select multiple edges using the Lasso select or Rectangle select tool or press the Shift key while you click the edges.
Select the orientation (front, side, or rear) and specify whether it is an interior or street edge.
Click Done to finish the edge orientation definition.
To learn more about calculating the orientation and street adjacency attributes in ArcGIS CityEngine, see the corresponding topic in the CityEngine documentation.
Copy parcels to a scenario
To copy parcels together with their spaces, overrides, edge orientation attributes, and custom ID, complete the following steps:
in the header to switch to development mode.Select the parcels you want to copy. See the Select parcels section above to learn more.
on the workflow toolbar.Click the Copy parcels to scenario button
from the Edit parcels tools.The Copy to scenario dialog box appears.
Select the target scenario from the drop-down list.
Choose the method to handle overlaps in the target scenario:
Preserve—All parcels in the target scenario are preserved. The copied parcels will be clipped if necessary.
Replace—All copied parcels are preserved. The parcels in the target scenario are clipped if necessary.
Click OK to copy the parcels.
The parcels are copied. The target scenario opens and the copied parcels are selected.
You cannot copy to the existing scenario.
If the source or the target parcels need to be clipped, review your edits carefully. Use undo if you encounter unexpected changes. The following situations might occur:
If the clipped parcel contains spaces, only spaces with their centroid still on the parcel are preserved.
The parcel edge orientation will be reset to side interior on clipped parcels. See the Edit parcel edges section above to learn how to review and modify parcel edges after copying.
If the clipped parcel is split into multiple parts, a multipart feature is created. Applying building types, showing envelopes, and editing parcel edges is currently not fully supported on those parcels. Use the split tool to split multipart parcels after copying. See the Split a parcel section above to learn more.
Edit the parcel Custom ID
To edit the Custom ID of a parcel, complete the following steps:
in the header to switch to development mode.Ensure that the side panel is expanded.
Select the parcel you want to edit. See the Select parcels section above to learn more.
In the side panel, browse to the Parcel information section.
Edit the parcel's Custom ID.
The parcel Custom ID label might be different depending on your urban model settings. See Configure a parcel label to learn how to configure the name of the Custom ID label in the data manager.
Edit parcel parameter values
To edit parcel parameter values of one or multiple parcels, complete the steps below.
Before you can edit parcel parameter values, you have to add parcel parameters to the metrics graph. See Add a metric to learn how.
Select the parcels you want to edit. See the Select parcels section above to learn more.
In the side panel, browse to the Parcel parameter table in the Parcel information section.
Click Add and select the parcel parameter you want to add a value to.
The parcel parameter is added to the table.
Click the Edit button
and add a parcel parameter value.To remove a parcel parameter from the table, click the Delete button
Instead of adding parcel parameter values manually, you can import them in the plan configuration. See Import parcel parameter values to learn more.
