Configure a plan
In the plan configuration, you can modify general plan settings, manage zoning and development data, set up metrics to be shown in the dashboard, and configure sharing.
Access plan settings
To access a plan's settings, complete the steps below.
Only users with an ArcGIS Urban license and editing permissions can configure zoning plans or land-use plans. Plans that are shared with everyone can only be configured by their owners.
Start ArcGIS Urban and sign in.
The overview appears.
Choose the plan you want to configure.
The plan editor appears.
Expand the drop-down menu named after the plan and choose Configure plan.
The plan configuration opens to the general plan settings tab by default. The tab is named after the plan. It is also referred to as the General tab.
Configure the plan.
See the sections below to learn what you can configure.
Click Return to plan
in the header when you finish the configuration.Click Return to overview
to go back to the overview.
Configure general settings
Click the tab that is named after the plan in the plan settings to do the following:
Configure the plan name, address, description, thumbnail, start and end date, and web page URL.
Review the coordinate system information.
Mark the plan as featured.
Configure the plan context.
Delete the plan.
Style the plan description with markdown syntax elements. See Description styling to learn more.
Featured plans are displayed at the top of the plans list.
Delete plan is only available for the plan owner.
Configure plan context
Context layers allow you to import specific layers that provide detail and understanding to the plan you are editing. Plan context layers display in all scenarios when you open a plan. They are not displayed in the overview. You can also configure context layers per scenario. See Configure scenario context to learn more.
To configure plan context, complete the following steps:
Browse to the Plan context section and click Select Item
.The Select plan context dialog box appears.
Select a web scene item from the list and click Select.
The item appears in the Plan context section.
in the header.The context layer is added to the plan.
The supported coordinate systems of context layers depend on the coordinate system of the urban model. See Understanding local and global urban models to learn more.
To switch context layers on or off when you're editing or viewing a plan, click the layer name on the Options menu
.Pop-ups that you configured in a web scene are shown together with the context layer when the Details side panel is open. To open it, click the Details button
at the upper right of the header.
Configure scenarios
Click the Scenarios tab to do the following:
Edit the name and description of scenarios.
Configure scenario context layers.
Configure a scenario elevation layer.
Add scenarios.
Reorder scenarios.
Lock scenarios.
Delete scenarios.
See Work with plan scenarios to learn more.
Configure zoning data
Click the Zoning tab to configure the data below. These settings are only available in zoning plans.
Zoning types
Zoning boundaries
Overlay types
Overlay boundaries
Manage zoning and overlay types
To manage zoning and overlay types, complete the following steps:
Click the Zoning tab and choose Zoning types or Overlay types.
Follow the steps described in Manage zoning types and Manage overlay types.
Add zoning and overlay boundaries
You can import zoning and overlay boundaries form a hosted feature layer to a scenario. To add boundaries, complete the following steps:
Click the Zoning tab and choose Zoning boundaries or Overlay boundaries.
Choose the scenario from the scenario drop-down menu.
Follow the steps described in Add zoning boundaries and Add overlay boundaries.
If a scenario already includes boundaries, you must delete the existing boundaries first.
The zoning boundaries are converted to the coordinate system of the urban model if the coordinate systems don't match.
Configure land-use data
Click the Land use tab to configure the data below. These settings are only available in land-use plans.
Land-use types
Land-use boundaries
Manage land-use types
To manage land-use types, complete the following steps:
Click the Land use tab and choose Land use types.
Follow the steps described in Manage land-use types.
Add land-use boundaries
You can import land-use boundaries from a hosted feature layer to a scenario. To add boundaries, complete the following steps:
Click the Land use tab and choose Land use boundaries.
Follow the steps described in Add land-use boundaries.
The land-use boundaries are converted to the coordinate system of the urban model if the coordinate systems don't match.
Configure development data
Click the Development tab to configure the following data:
Parcels and parcel parameters
Space-use types
Building types
Spaces
Add parcels
You can import parcels from a hosted feature layer or from the urban model to a scenario. To add parcels, complete the following steps:
Click the Development tab and choose Parcels.
Click Add and choose from the following options:
From Urban Model—Import parcels from the urban model. The parcels are automatically imported.
From feature layer—Import parcels from a feature layer. Follow the steps described in Add parcels.
If a scenario already includes parcels, you must delete the existing parcels first.
The parcels are converted to the coordinate system of the urban model if the coordinate systems don't match.
The import skips parcels with invalid geometry.
Import parcel parameter values
To import parcel parameter values to your parcels, complete the steps below.
Before you can import parcel parameter values, you have to add parcel parameters to the metrics graph. See Add a metric to learn how.
Click Add in the Parameter data column for a parcel parameter listed in the Parcel parameters table.
The Import parcel parameters dialog box appears.
Import parcel parameter values:
In the Item step, search for the ArcGIS Online layer that contains the parcel parameter values. Click the layer and click Next to continue.
Your parcel parameter values need to be stored in a polygon feature layer.
In the Sublayer step, select a sublayer, and click Next to continue.
In the Fields step, use the Fields in source drop-down menu to configure the source field that contains the ID that matches the Custom ID of the parcels. Parcel parameter values are only imported for parcels in which the ID in the parcel parameter feature layer matches the Custom ID in the parcels layer.
Configure the source field that contains the parcel parameter values.
Optionally, use the Units in source drop-down menu to configure the units in the data source.
In the Fields step, click Next.
In the Validation step, review invalid features in the Errors table if errors are detected. Correct the errors in the source data and click Refresh. If all features are valid, click Next or wait for 5 seconds to start the import.
In the Import step, ensure that all features are imported. Click Close to close the dialog box.
In the Validation step, the number of features validated in the data source is shown, whereas in the Import step, the number of features imported to the urban database is displayed. The numbers can differ if not all parcels receive a parcel parameter.
Manage space-use and building types
To manage space-use and building types, complete the following steps:
Click the Development tab and choose Space use types or Building types.
Follow the steps described in Manage space-use types or Manage building types.
Add spaces from building footprints
To add building spaces by uploading building footprints, complete the following steps:
Click the Development tab and choose Spaces.
Follow the steps described in Generate buildings from footprints.
The footprints are converted to the coordinate system of the urban model if the coordinate systems don't match.
Configure the dashboard
Click the Dashboard tab to do the following:
Add and edit metrics to be shown in the plan's dashboard.
Explore metrics in the graph view.
Add existing metric values.
See Configure the dashboard for additional details.
Configure sharing settings
Click the Sharing tab to do the following:
Share the plan with individual users, groups, or the public.
Allow nonowners to edit.
Allow nonowners to save the plan as a duplicate.
See Share a plan for more information.
The sharing settings are only available if you are the plan owner.
