Work with plan scenarios
You can create scenarios based on existing scenarios and edit them if you have editing privileges and an Urban license. You can switch between scenarios to compare different plan proposals and analyze metrics, building space use, and zoning or land-use area.
By default, a plan has two scenarios: the existing conditions and the new (future) conditions. To learn more about how to develop parcels in scenarios, see Develop a parcel.
Create a scenario
To create a scenario while editing a plan, complete the following steps:
Click a plan in the view or find it in the search panel.
The plan editor opens.
Click the Configure scenarios button
in the center of the header.The Scenarios dialog box appears.
Click Add Scenario.
Provide a name for the new scenario and choose the scenario on which the new scenario will be based.
Click OK.
The new scenario appears on the Scenarios dialog box.
Optionally, click the new scenario and add a description and a context web scene.
Click OK.
Configure scenario settings
Everyone who can edit a plan can configure the settings of a scenario. You can configure the following scenario settings:
Edit the scenario name and description.
To configure the settings of a scenario, complete the following steps:
Click the scenario for which you want to configure the settings.
The scenario settings expand.
Configure scenario context
Context layers allow you to import specific layers that provide detail and understanding to the scenario you are viewing or editing. They are not displayed in the overview. You can also configure context layers that display for all scenarios. See Configure plan context to learn more.
To configure scenario context, complete the following steps:.
In the Scenario context section of the scenario settings, click the Select scenario context button
.The Select scenario context dialog box appears.
Select a web scene or a scene layer item from the list and click Select.
The item appears in the Scenario context section.
Click OK to close the Select scenario context dialog box.
The scenario context is loaded and displayed in the scene.
The supported coordinate systems of context layers depend on the coordinate system of the urban model. See Understanding local and global urban models to learn more.
To switch context layers on or off when you're editing or viewing a plan, click the layer name on the Options menu
.Pop-ups that you configured in a web scene are shown together with the context layer when the Details side panel is open. To open it, click the Details button
at the upper right of the header.
Configure a scenario elevation layer
To add an elevation layer to your scenario, follow the steps below. This layer overrides the elevation configured in the data manager. See Configure an elevation layer to learn more.
In the Elevation section of the scenario settings, click the Select scenario elevation button
.The Select scenario elevation dialog box appears.
Select an elevation layer item from the list and click Select.
The item appears in the Elevation section.
Click OK to close the Select scenario elevation dialog box.
The elevation layer is loaded and displayed in the scene.
When you change the elevation layer, the elevation of previously created buildings is not modified. See Edit building spaces to learn how to edit the elevation of a building to align it with the new elevation layer.
Lock a scenario
Everyone who can edit a plan can lock scenarios in that plan. This prohibits users from accidentally editing a scenario. In the plan editor, the following actions are disabled for locked scenarios:
Details mode
—Uploading imagesZoning mode
(zoning plans)—Editing zoning and overlay boundaries as well as parcel overridesLand-use mode
(land-use plans)—Editing land-use boundaries and parcel overridesDevelopment mode
—Editing parcels, applying building types, editing spaces, and demolishing parcelsDashboard mode
—Editing existing metric values in the existing scenario
The data of a locked scenario can still be configured in the plan settings by everyone who can edit the plan. See Configure a plan to learn more.
In addition, some actions on the plan level can affect locked scenarios. Everyone who can edit a plan can perform the following actions:
Edit types, such as zoning, land-use, overlay, space-use, and building
Edit suitability models
Edit analysis
Edit the dashboard
Edit metrics in the plan configuration
Edit the study area
To lock a scenario, complete the following steps:
On the scenarios dialog box, find the scenario you want to lock and click the lock button next to the scenario name.
Click OK.
The scenarios dialog box closes.
Change the scenario order
To change the order of the scenarios in the scenario switcher, complete the following steps:
Select the scenario you want to reorder and drag it to its new position.
The scenario is moved to the new location.
Click OK.
The scenario configuration dialog box closes.
