Edit a project
You can edit all aspects of a project by creating scenarios and comparing them to the existing conditions. The editing functions in a project include the following:
  • Edit the study area.
  • Demolish underlying conditions.
  • Upload and store detailed 3D models.
  • Add assets such as trees, vehicles, and street furniture.
  • Sketch building volumes with a defined height.
  • Sketch ground surfaces.
  • Explore zoning, land use, and parcel data.
If a project is shared with everyone, only the owner can edit it. You cannot edit projects that you uploaded to the urban database through the data manager. You cannot edit the existing conditions scenario.
Start editing
To edit a project, complete the following steps:
  1. Select the project you want to edit in the view or locate it using the search panel on the upper corner of the overview.
    The project editor opens.
  2. Click the Development button from the toolbar at the side of the view.
    The development mode toolbar appears.
  3. Use the editing tools from the context toolbar.
  4. Adjust the view by turning on or off the demolition area, ground surfaces, building volumes, and assets such as trees, vehicles, and street furniture in the layer list. Click the Layers button at the upper corner of the view to open the Layers list.
Edit the study area
To edit the study area, complete the following steps:
  1. Click the Info button from the toolbar at the side of the view.
    The Project info side panel opens.
  2. Click the Edit project info button in the side panel's header.
    The Project info side panel switches into editing mode. The study area becomes editable.
  3. Edit the study area by clicking and dragging its vertices.
    • To add a vertex, click the orange dot between two existing vertices.
    • To remove a vertex, right-click it.
    • This tool supports snapping. To disable snapping temporarily, press the Ctrl key while drawing.
    • This tool supports editing constraints. Press the Tab key while drawing to input exact dimensions.
  4. Click the Return to project info button in the side panel's header to complete the study area editing.
See the Demolish existing conditions section below to learn how to edit the demolish area according to the study area.
Use the demolish tool to remove existing buildings and trees from the view. The demolish tool allows you to do the following:
  • Demolish all existing buildings and trees intersecting the project's study area. See the Demolish existing conditions by study area section below to learn more.
  • Use a custom demolish area to remove selected existing buildings and trees. See the Work with custom demolish areas section below to learn more.
  • Edit a demolish area. See the Edit a demolish area section below to learn more.
  • Remove selected demolish areas. See the Remove a demolish area section below.
The demolish area you create in the scenario configured to be visible in the overview will be used in the overview to mask existing buildings and trees for everybody who has access to the project. To show a different scenario in the overview, see Configure the scenario visible in the overview.
To demolish all existing building and trees intersecting the project's study area, complete the following steps:
  1. Click the Development button from the toolbar at the side of the view.
  2. Choose the Demolish study area option from the Demolish drop-down menu.
    The study area is visualized in orange with a dotted outline. Existing buildings and trees intersecting the study area are removed from the view.
You can draw a custom demolish area to remove existing buildings and trees. To draw a custom demolish area, complete the following steps:
  2. Choose the Demolish custom area option from the Demolish drop-down menu.
  3. Draw a custom demolish area on the map.
  4. Double-click to complete the drawing.
    The custom demolish area is visualized in orange with a dotted outline. Existing buildings and trees intersecting the demolish area are removed from the view.
To edit the geometry of a demolish area, complete the following steps:
  2. Click the Select button in the toolbar to activate the selection tool.
  3. Click the outline of the demolish area you want to edit.
    The editing toolbar appears underneath the demolish area polygon.
  4. Click the Edit button .
    You can edit the vertices of the demolish area polygon.
To remove a demolish area, complete the following steps:
  4. Click the Delete button .
    The selected demolish area is removed from the view.
Add and edit assets
You can do the following when working with assets such as trees, vehicles, and street furniture in a project:
  • Change the type of an existing asset.
  • Reposition the asset.
  • Duplicate an asset within the same scenario or copy it to another scenario.
  • Delete an asset.
  • Assets such as trees, vehicles, and street furniture are only visible in the project editor. They are not displayed in the overview.
  • Assets are always placed on the terrain. It is not possible to position assets on top of existing buildings or proposed building volumes.
Add assets
To add assets such as trees, vehicles, and street furniture when editing a project, complete the following steps:
  2. Click the Add asset button .
    The asset picker drop-down menu appears.
  3. Select the asset to place in the project.
  4. Click the map to place the asset or press the Tab key to input exact coordinates.
    The asset is placed in the map.
  5. Press the Esc key to exit the tool.
Edit assets
To edit assets, complete the following steps:
  3. Click the asset you want to edit.
    The editing toolbar appears underneath the asset.
  4. Choose from the asset editing tools according to your requirements:
    • Use the handles in the view to scale, rotate, or move the currently selected asset.
    • Asset type drop-down menu—Change the type of an existing asset.
    • Duplicate Duplicate—Duplicate the currently selected asset.
    • Remove Remove—Remove the currently selected asset.
    • Select the Locate option from the More drop-down menu to move the asset to a specific location by inserting coordinates.
    • Select the Duplicate to option from the More drop-down menu to copy the currently selected asset to another scenario.
Add and edit volumes
You can do the following when working with building volumes in a project:
  • Sketch new building volumes.
  • Change the height of a building volume.
  • Reshape and reposition the geometry.
  • Duplicate a building volume within the same scenario or copy it to another scenario.
  • Delete a volume.
Building volumes you create in the scenario configured to be visible in the overview, will be visible in the overview as future developments for everybody who has access to the project. See Configure the scenario visible in the overview to show a different scenario in the overview.
Sketch new volumes
To sketch new building volumes in a project, complete the following steps:
  2. Choose the Sketch volumes option from the Sketch drop-down menu.
    The context input text field to define the height of the building volume appears.
  3. Provide a numeric value in the text field to define the height of the building.
  4. Draw the building footprint.
  5. Double-click to complete the drawing.
  6. To add more buildings to the project, repeat steps 2 through 5.
    You can draw buildings on top of each other to create a podium and tower effect.
Edit volumes
To edit building volumes, complete the following steps:
  3. Click the building volume you want to edit.
    The editing toolbar appears underneath the volume.
  4. Choose from the volume editing tools according to your requirements:
    • Use the handles in the view to rotate or move the currently selected volume.
    • Height input field—Change the height of a building volume.
    • Reshape geometry Reshape geometry—Add vertices and move and remove existing vertices.
      This tool supports snapping. To disable snapping temporarily, press the Ctrl key while editing.
    • Duplicate Duplicate—Duplicate the currently selected building volume.
    • Remove Remove—Remove the currently selected building volume.
    • Select the Duplicate to option from the More drop-down menu to copy the currently selected building volume to another scenario.
Add and edit surfaces
You can do the following when working with ground surfaces in a project:
  • Sketch new ground surfaces.
  • Change the type of an existing surface.
  • Duplicate a surface polygon within the same scenario or copy it to another scenario.
  • Delete a surface.
Ground surfaces are only visible in the project editor. They are not displayed in the overview.
Sketch new surfaces
To sketch new ground surfaces in a project, complete the following steps:
  2. Choose the Sketch surfaces option from the Sketch drop-down menu.
    The ground library context drop-down menu appears.
  3. Choose between Grass, Concrete, or Water.
  4. Draw the ground area.
Edit surfaces
To edit ground surfaces, complete the following steps:
  3. Click the ground surface you want to edit.
    The editing toolbar appears underneath the surface.
  4. Choose from the surface editing tools according to your requirements:
    • Use the handles in the view to rotate or move the currently selected surface.
    • Surface type drop-down menu—Change the type of a surface polygon.
    • Duplicate Duplicate—Duplicate the currently selected surface polygon.
    • Remove Remove—Remove the currently selected surface polygon.
    • Select the Duplicate to option from the More drop-down menu to copy the currently selected surface polygon to another scenario.
Work with envelopes
Envelopes display the maximum extent of potential buildings. This is constrained by height, setback, and skyplane restrictions on each parcel. While additional controls such as floor area ratio (FAR) and parcel coverage often limit the actual buildable volume, the envelope illustrates the spatial extent where development is permitted. You can use envelopes to visually verify whether a building volume or a 3D model associated with a project scenario complies with the underlying zoning regulations.
Any user who can view a project can show and hide the envelopes of the parcels that intersect with the study area of the project. Users with editing permissions can additionally select individual envelopes and explore the underlying zoning, land use, and parcel data.
Show envelopes
To show envelopes in a project, complete the following steps:
  1. Click the Layers button from the toolbar at the upper corner of the view.
    The Layers list opens.
  2. Click the Expand button next to the Base layers section in the Layers list.
  3. Click the Envelopes entry.
    Envelopes are displayed in the 3D map view for all parcels that intersect the study area of the project.
For users with editing permissions: You cannot select and interact with assets, building volumes, and surfaces that are inside an envelope. It is recommended that you hide envelopes while editing. See the Hide envelopes section below to learn more.
Hide envelopes
To hide the envelopes in a project, complete the following steps:
    Envelopes are no longer displayed in the 3D map view.
Complete the following steps to explore the underlying zoning, land use, and parcel data associated with an envelope:
  1. Ensure envelopes are displayed.
    See the Show envelopes section above to learn how you can display the envelopes in the project editor.
  3. Click the Select button on the toolbar to activate the selection tool.
  4. Click the envelope that corresponds to the parcel you want to learn more about in the 3D map view.
  5. Click the Details button from the toolbar at the upper side of the view.
    The Details side panel expands. It displays information about the parcel (parcel area, parcel ID, and parcel edge orientation) as well as information about the zoning, the existing land-use, and the future land-use parameters applicable to the selected parcel as stored in the urban model system of record.
