Configure a project
You can configure the following aspects of a project:
Use the Edit project info side panel to modify general project information.
Use the Share dialog box to configure sharing.
Use the Scenarios dialog box to configure scenarios.
Only users with an ArcGIS Urban license and editing permissions can edit projects.
For projects that you uploaded to the urban database through the data manager, you cannot configure scenarios, edit the study area, or change the sharing settings.
Configure general project information
Use the Edit project info side panel to do the following:
Configure the project name, custom ID, address, description, thumbnail, start and end date, and web page URL.
Set the project status.
Configure which scenario is visible in the overview as well as in other plans and projects.
Review the coordinate system information.
Mark the project as featured.
Complete the following steps to open the Edit project info side panel:
Choose the project you want to configure.
The project editor appears and the Info side panel opens by default.
Click the Edit project info button
in the side panel's header.The Project info side panel switches into editing mode.
Configure the project information.
Click the Return to project info button
in the side panel's header when you finish the configuration.
See Manage project status types to learn more about how to configure project status types in the data manager.
See Configure the scenario visible in the overview to learn more about how to define which scenario is visible in the overview as well as in other plans and projects.
Style the project description with markdown syntax elements. See Description styling to learn more.
Featured projects are displayed at the top of the projects list.
You can configure which project scenario is visible in the overview as well as in other plans and projects for everybody who has access to the project. Complete the following steps to do so:
Open the Edit project info side panel as described in Configure general project information.
From the scenarios drop-down menu in the header, select the scenario that you want to be visible in the overview.
Click Set current in the Scenario visible in overview section of the Edit project info side panel.
The scenario gets marked with a star icon
in the scenarios drop-down menu.Only the building volumes, the 3D models, and the demolition area of the selected scenario will be visible in the overview as well as in other plans and projects.
If you don't want any project scenario to be visible in the overview, click Reset in the Scenario visible in overview section of the Edit project info side panel.
Configure scenarios
Expand the scenarios drop-down menu in the header and choose Scenario settings to do the following:
Edit the name and description of scenarios.
Configure a scenario context layer.
Configure a scenario visualization.
Add scenarios.
Reorder scenarios.
Delete scenarios.
See Work with project scenarios to learn more.
Configure sharing settings
Expand the drop-down menu named after the project in the header and choose Share project to do the following:
Share the project with individual users, groups, or the public.
Enable editing for nonowners.
Allow nonowners to save the project as a duplicate.
See Share a project for more information.
The sharing settings are only available if you are the project owner.
Delete a project
To delete a project, complete the following steps:
Expand the drop-down menu named of the project in the header and choose Delete project.
The Delete dialog box appears.
Confirm the deletion of the project and click Delete.
The project is deleted and the app returns to the overview.
Delete project is only available for the project owner.
