Work with project scenarios
You can create scenarios based on existing scenarios and edit them if you have an Urban license and editing privileges. You can switch between scenarios to compare designs. By default, a project has two scenarios: the existing conditions and the new (future) conditions. The scenario that is marked with a star icon is also visible in the overview as well as in other plans and projects for everybody who has access to the project. See Configure the scenario visible in the overview to learn how to define which scenario is visible in the overview.
Create a scenario
To create a scenario while editing a project, complete the following steps:
Click a project in the view or find it in the search panel.
The project editor opens.
Expand the scenarios drop-down menu in the header and choose Scenario settings.
The Scenarios dialog box appears.
Click Add scenario.
Provide a name for the new scenario and choose the existing scenario on which the new scenario will be based.
Click OK.
The new scenario appears on the Scenarios dialog box.
Optionally, click the new scenario and add a description, configure a visualization, or a context web scene.
Click OK.
Configure scenario settings
Everyone who can edit a project can configure the settings of a scenario. You can configure the following scenario settings:
Edit the scenario name and description.
Configure a scenario visualization.
Configure scenario context.
Lock a scenario.
To configure the settings of a scenario, complete the following steps:
Click the scenario for which you want to configure the settings.
The scenario settings expand.
The project scenario visualization layer allows you to import an external 3D visualization of the project design to the scenario. See Add external 3D content to learn how to do this.
Context layers allow you to import specific layers that provide detail and understanding to the scenario you are viewing or editing. They are not displayed in the overview.
To configure the scenario context, complete the following steps:.
In the Scenario context section of the scenario settings, click the Select scenario context button
.The Select scenario context dialog box appears.
Select a web scene or a scene layer item from the list and click Select.
The item appears in the Scenario context section.
Click OK to close the scenarios dialog box.
The scenario context is loaded and displayed in the scene.
The supported coordinate systems of context layers depend on the coordinate system of the urban model. See Understanding local and global urban models to learn more.
To switch context layers on or off when you're editing or viewing a project, click the layer name in the Context layers section of the Layers list. Click the Layers button
at the upper right of the view to open the Layers list.Pop-ups that you configured in a web scene are shown together with the context layer when the Info side panel is open. To open it, click the Info button
from the buttons at the left of the view.If the scenario context includes an elevation layer, this terrain is used when viewing the scenario instead of the elevation layer defined in the urban model. See Custom elevation layer to learn more.
Lock a scenario
Everyone who can edit a project can lock scenarios. This prohibits users from accidentally editing a scenario.
You can still edit the name, scenario visualization, scenario context, and description of a locked scenario.
To lock a scenario, complete the following steps:
In the scenarios dialog box, find the scenario you want to lock and click the lock button next to the scenario name.
Click OK.
The scenarios dialog box closes.
Change the scenario order
To change the order of the scenarios in the scenario drop-down menu, complete the following steps:
Click the scenario you want to reorder and hold the mouse button. Move the scenario to its new position and release the mouse button.
The scenario is moved to its new location.
Click OK.
The scenario configuration dialog box closes.
