Feature Layer
The Feature Layer source type in ArcGIS Velocity loads features from a feature layer.
Examples
The following are example use cases for the data source:
  • A user selects an ArcGIS Online hosted feature layer containing the features to load.
  • A GIS analyst provides the URL to an ArcGIS Server feature layer (for example, https://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/2) containing the features to load.
  • A user can add real-time weather conditions to their map by incorporating a weather feature layer from ArcGIS Online.
Usage notes
Keep the following in mind when working with the data source:
  • When browsing a feature layer item, you can filter by folders, favorites, groups, or organization. You can filter further by date modified, date created, and tags.
  • ArcGIS Server feature layers can also be loaded using a URL. Use an ArcGIS Server services directory REST URL (for example, https://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/2). This URL should end in /FeatureServer/# or /MapServer/# in which # is the layer number.
  • To load a secured feature layer from a URL, first add items from the web to ArcGIS Online and store credentials, then browse to the registered ArcGIS Online item to load the secured feature layer.
  • Feature layers must have a unique identifier field. The unique identifier must not be null, must contain unique values, and must be one of the following data types:
    • Integer (32- and 64-bit positive values only)
    • String
    • GUID
    • Date
    • Date only
    • Time only
  • Feature layers must have a unique identifier that supports the Min and Max summary statistics operations. When using an ArcGIS Server feature layer, keep in mind that some service backends do not support virtual object ID fields, such as ESRI_OID.
  • If a field is provided for the Timestamp field parameter, the Feature Layer source queries the feature layer to only load features relevant to the current analytic run (scheduled analytics only).
    • If the Timestamp field value is provided, when the analytic is started the first time, Velocity polls the feature layer and loads all features with a timestamp field datetime less than the first scheduled run time that also meets the criteria of the WHERE clause. For each subsequent run, only features with a timestamp field value between the last scheduled run time and the current scheduled run time that also meets the criteria of the WHERE clause are loaded.
    • If no Timestamp field value is provided, each time the analytic is started, the Feature Layer feed loads all features from the feature layer as events to be processed.
  • A timestamp field cannot be specified when configuring a feature layer source in a real-time analytic, because each time the real-time analytic is started, the feature layer feed loads all features returned by the configured where clause.
  • After configuring the source connection parameters, refer to configuring input data to learn how to define the schema and the key parameters.
  • For optimal polling performance, if available it is recommended to create an attribute (field) index on the Date field for latest features option referenced by the Timestamp field parameter. This improves query efficiency when filtering records between polling intervals. Attribute (field) indexes can only be created on feature layers that are owned or administered by the Velocity user.
Parameters
The following are the parameters for the data source:
Parameter
Data type
WHERE clause
A Structured Query Language (SQL) clause used to filter features loaded from the specified feature layer. The default is to load all features using 1=1 and can be modified to include specific attribute values and logic conditions.
Most feature layers support SQL-92 WHERE clause syntax on the fields in the layer.
Feature layers generated by Velocity or feature layers in ArcGIS Enterprise running on a spatiotemporal big data store source have restrictions on what is supported; they only support a subset of SQL-92. The supported SQL-92 syntax with these feature layers are as follows:
  • ( '<=' | '>=' | '<' | '>' | '=' | '!=' | '<>' | LIKE )
  • (AND | OR)
  • (IS | IS_NOT)
  • (IN | NOT_IN) ( '(' ( expr ( ',' expr )* )? ')' )
  • COLUMN_NAME BETWEEN LITERAL_VALUE AND LITERAL_VALUE
If you're using analytic global variables to restrict feature loading, four global variables pertain to recurring big data analytics and are listed below. These variables can be used in conjunction with the feature layer source WHERE clause to only load certain features each time the big data analytic runs.
  • $analytic.AnalyticLastScheduledStartTime—The time the last run of the analytic was scheduled to start.
  • $analytic.AnalyticScheduledStartTime—The time the current run of the analytic was scheduled to start.
  • $analytic.AnalyticLastEndTime—The time the last run of the analytic ended.
  • $analytic.AnalyticStartTime—The time the current run of the analytic started. The difference between this and $analytic.AnalyticScheduledStartTime is the startup delay.
Use these variables most commonly in conjunction with a real-time analytic that is continuously writing events to a feature layer output as the events occur.
Learn more about near real-time analysis
QueryString
Out fields
Loads the fields from the feature layer into Velocity.
The default is the asterisk (*), which loads all fields.
When specifying fields, use a comma-separated list of field names, for example: device_id,timestamp,horizontal_accuracy,latitude,longitude.
String
Output spatial reference
The well-known ID (WKID) of a spatial reference. The default is 4326.
String
Additional logging
(optional)
Specifies whether Velocity turns on logging for raw requests. The default is False.
Turn on this parameter only for troubleshooting, then turn it off when complete. Contact Esri Technical Support for help with troubleshooting.
Boolean
Timestamp field
A date field for retrieving the latest features (scheduled analytics only).
Learn more about timestamp field settings
String
Considerations and limitations
Consider the following when using the data source:
  • The feature layer must be accessible on the internet.
  • Velocity does not reference layers that require credits to receive requests (ArcGIS Online).
