Create and manage user-defined settings
Available with Workflow Manager license.
User-defined settings provide a secure way for workflow item administrators to store information, such as credentials for a web request or commonly used file paths. Stored settings are available in your workflows as dynamic job properties.
You can use encrypted user-defined settings only in the items that the following table contains:
Item Where supported
Webhook job creation Username, Password, Fallback Username, and Fallback Password; Header Name, Value, and Secret
Send Web Request step or web request template Authorization tab, Body tab
Reconcile and Post step Run as different user credentials
Add user-defined settings
To add user-defined settings, do the following:
  1. Access the Workflow Manager web app.
  2. Click the Design tab.
    The Design page appears.
    If you don't have sufficient privileges, the Design tab is not available.
  3. Click Settings .
    If you don't have sufficient privileges, Settings is not available.
  4. Click the User Defined Settings tab.
  5. Click Add Setting.
  6. Provide a name for the setting in the Name text box.
  7. Provide a value for the setting in the Value text box.
  8. Optionally, check the Encrypt check box to encrypt the stored value.
    If you are transitioning from a federated Workflow Manager Server site to workflow management services in ArcGIS Enterprise on Kubernetes and have encrypted user-defined settings, the values are blank after the transition and must be updated in each workflow item.
  9. Repeat steps 5 through 8 to add more settings.
  10. Click Save to save the settings.
Edit user-defined settings
To edit user-defined settings, do the following:
  3. Click Settings .
  5. Update the settings as necessary.
  6. Click Save to save the changes.
Delete user-defined settings
Deleting a user-defined setting is permanent and can't be undone. To delete user-defined settings, do the following:
  3. Click Settings .
  5. Hover over the setting you want to delete and click Delete Setting .
    The Delete User Setting dialog box appears.
    Caution:
    Deleted user settings can't be recovered.
  6. Click Yes to delete the setting or click No to cancel.
