Add and configure Reconcile and Post
Available with Workflow Manager license.
The Reconcile and Post step allows you to retrieve and post edits between a branch version and the default version using the Version Management Service reconcile operation . This step is commonly used in combination with the Create Replica step as part of an offline editing workflow.
When working in a branch version, the reconcile process detects conflicts between the branch version and the default version before pulling changes to the branch version. Edits from the branch version can then be merged to the default version using the post process.
When the step is run, the following actions can be performed:
Refresh Step
—If you are assigned to the step or have the adminAdvanced or adminBasic privilege, re–check the status of the step if the connection to the server was disrupted.
The step must be configured with the Run as asynchronous job option to re-check the status of the step when the job is run.
Complete Step
—Finish the step.
Configure the step
To configure the step, do the following:
Create or edit a workflow diagram to access the Step Library panel.
Drag Reconcile and Post from the Step Library panel to a connection arrow of a step on the workflow canvas.
Learn more about adding steps to a workflow diagram
The Step Details panel appears.
Provide a name for the step in the Step Name text box.
In the Data Sources section, choose one of the following methods for evaluating data references:
All—Evaluate all feature service data references configured with the workflow diagram.
Only feature service data references hosted on the current ArcGIS Enterprise portal that have the branch versioning capability will be evaluated.
Select Sources—Choose specific feature service data references to evaluate from the drop-down menu.
If you don't have a feature service data reference associated with the workflow diagram, click Add data reference from the drop-down menu and add a data reference by doing one of the following:
Browse for item—Browse and choose from a list of items on the current portal.
Tip:
You can refine results by applying filters and tags to the search.
Enter item ID manually—Provide the item ID and reference name in the Item ID and Reference Name text boxes.
The item is automatically validated by Workflow Manager and the data reference type is set.
If the data reference cannot be validated, you must provide the item ID to a valid data reference that matches the set data reference type.
Arcade Expression—Provide an ArcGIS Arcade expression that returns the data reference's item ID to dynamically determine the feature service data reference to evaluate when the step is run.
The Arcade expression must return the data reference ID, not the data reference name.
Tip:
Click This input supports Arcade Expressions
and choose an Arcade expression to add it to its associated text box.
In the Conflict Detection section, choose one of the following options to define the condition for detecting conflicts:
By Object—Mark changes made to the same row or feature as a conflict.
By Attribute—Mark changes made to the same column or feature as a conflict.
Check the following check boxes as necessary:
Abort reconcile if conflicts detected—Cancel the reconcile process if conflicts are detected.
Post versions after reconcile—Post the current version to the default version after reconciling.
Run as asynchronous job—Reconcile the versions sequentially.
Run as different user—Provide the credentials of a user who can run the step if the user assigned to the job does not have access to the branch version.
Caution:
Authentication information provided in the step is not encrypted. Information can be stored securely by adding an encrypted user-defined setting that can be referenced in the step using dynamic job properties.
Click the Options tab.
Configure Step Options as necessary:
Manual—Run the step manually.
- Optional—Allow the step to be finished without being run.
Automatic—Run the step as soon as it becomes active.
If the workflow diagram is configured to automatically run a sequence of steps that includes the Evaluate Data Quality or the Run GP Service step, steps that attempt to run after the user token expires will not run automatically. The ArcGIS Workflow Manager Server Advanced role is required to run additional automated steps without manual intervention.
Run on a Schedule—Run the step according to a set schedule.
Optionally, choose one of the following options to configure help in the step:
None—Configure the step without step help.
Text—Configure help text for the step in the Text text box.
You can use ArcGIS Arcade expressions to provide a dynamic value for the step help. If the step help contains plain text and Arcade expressions, format the text as follows:
'For further assistance, please contact' + JobCreator($Job) + '.'URL—Configure the step with a link to a help resource in the URL text box.
Steps that are run in the web app only support HTTP and HTTPS URL formats. Steps that are run in ArcGIS Pro support HTTP, HTTPS, and file formats.
You can also use Arcade expressions to provide a dynamic value. If the URL contains plain text and Arcade expressions, format the text as follows:
'https://pro.arcgis.com/en/pro-app/latest/tool-reference/' + JobExtendedProperty($Job, 'tools', 'toolbox') + '/' + jobExtendedProperty($job, 'tools', 'alias') + '.htm'Configure the Automatically Encode Arcade Result check box as follows:
If an Arcade expression returns special characters that must be escaped when converted to a URL, such as a space or a forward slash, ensure that the Automatically Encode Arcade Result check box is checked.
If an Arcade expression is used to form the base URL, uncheck the Automatically Encode Arcade Result check box.
Optionally, click the Style tab to change the shape and color of the step.
Optionally, click the About tab and provide a description for the step in the Step Description text box.
Tip:
The About tab also contains the step's ID that can be used with dynamic job properties to obtain a step's output. Click Copy Step ID
to copy the step ID to the clipboard.
Return value
When the step is completed, its return value is stored to indicate the result of the step. The return value can be immediately evaluated using paths to determine the next steps in the workflow. You can also retrieve the return value for completed steps throughout the workflow using ArcGIS Arcade expressions. The following table lists the step's return values:
Return value |
Description |
S000001 |
The step completed successfully. |
F000001 |
The step failed to complete successfully. |
Output value
When the step is completed, its output value is stored and can be used to determine the path the workflow follows or can be used as inputs for other steps throughout the workflow. The following table lists the step's output values:
Output |
Description |
version |
Returns the current version. |
dataSourceNames |
Returns an array of data references associated with the current version. |
