Workflow functions
Available with Workflow Manager license.
The following sections contain ArcGIS Arcade expressions that allow you to access the history of work performed on a job. This includes obtaining results from specific steps, webhooks, and the last person assigned to a step. These expressions don't attach files or logs to a job, but they can be used to guide the workflow, assign steps to specific users or groups, and access specific types of output values.
LastRunner
The LastRunner expression returns the username of the last person who ran the specified step. This expression is typically used in workflows that include a quality assurance or quality control review in which work may need to be redirected back to the person who originally performed edits to resolve issues that were identified during the review process.
Parameters
LastRunner(job_id, step_id)
Name |
Explanation |
Data type |
job_id |
The ID of the job. |
String |
step_id |
The ID of the step in the workflow diagram. |
String |
Output
Returns a string value of the username of the last person who ran the specified step.
Expression sample
The following expression returns the username of the last person who ran the current job's specified step:
LastRunner($Job, 'f50d740d-cc04-9296-4ce3-181e82604465')
Example output
jdoe
JobReturnValue
The JobReturnValue expression returns a completed step's return value. This expression is typically used to confirm whether a step failed or was successful, and it is commonly used when investigating steps that have failed to run properly.
Parameters
JobReturnValue(job_id, step_id)
Name |
Explanation |
Data type |
job_id |
String |
step_id |
String |
Output
Returns a string value of the specified step's return value for the specified job.
Expression sample
The following expression returns the return value of the specified step for the current job:
JobReturnValue($Job, 'f50d740d-cc04-9296-4ce3-181e82604465')
Example output
S000001
JobOutputValue
The JobOutputValue expression returns the output value for a completed step or the output value for a completed webhook action.
Parameters for step output values
JobOutputValue (job_id, step_id, {value_name})
Name |
Explanation |
Data type |
job_id |
String |
step_id |
String |
value_name (Optional) |
The specific output value key for steps with multiple output values. The first value is returned by default. |
String |
Parameters for webhook action output values
JobOutputValue (job_id, action_type, {value_name})
Name |
Explanation |
Data type |
job_id |
String |
action_type |
The name of the webhook action that created the output value. Currently, |
String |
The specific output value key for webhook actions with multiple output values. The first value is returned by default. |
String |
Output
Returns a string value of the output value for a completed step or the output value for a completed webhook action.
Expression samples
The following expression returns the num_acres step output value for a Run GP Service step:
JobOutputValue($Job, 'd27395ec-ddfe-2b11-777a-6df02e86d835', 'num_acres')
Example output
123
The following expression returns the errorsIdentified step output value for an Evaluate Data Quality step:
JobOutputValue($Job, '0105f656-1cd0-4424-af9b-f75ede7fdcf0', 'errorsIdentified')
Example output
The following expression returns the Status step output value for a Send Web Request step:
JobOutputValue($Job, 'e31395eb-dafc-2a11-777c-6da02c86e122', 'Status')
Example output
200
The following expression returns the Request Number output value for the CreateJob webhook action:
JobOutputValue($Job, 'CreateJob', 'Request Number')
Example output
123456
JobOutputArray
The JobOutputArray expression returns a completed step's output value or a completed webhook action's output value as an Arcade array type. This expression can only be used with the Create Version step, the Send Web Request step, and webhook output values.
JobOutputArray(job_id, step_id, {value_name})
Name |
Explanation |
Data type |
job_id |
String |
step_id |
String |
String |
JobOutputArray(job_id, action_type, {value_name})
Name |
Explanation |
Data type |
job_id |
String |
action_type |
String |
String |
Output
Returns the JSON string array of a completed step's output value or a completed webhook action's output value as an Arcade array type.
Expression example
The following expression returns the dates output value for the current job's specified step:
JobOutputArray($Job, 'd27395ec-ddfe-2b11-777a-6df02e86d835', 'dates')
Example output
['2022-01-20', '2022-02-21']
The following expression returns the dates output value for the CreateJob webhook action:
JobOutputArray($Job, 'CreateJob', 'dates')
Example output
