Job property functions
Available with Workflow Manager license.
The following sections contain ArcGIS Arcade expressions that allow you to retrieve job information managed by ArcGIS Workflow Manager. Many of the values for job properties are initially set when the job is created and are based on the values defined in the job template. Job properties can be manually updated in the Details panel or updated by running steps.
Tip:
To access business-specific properties that were configured by your organization, use extended properties expressions.
JobDescription
The JobDescription expression returns the description associated with a job.
Parameters
JobDescription(job_id)
Name
Explanation
Data type
job_id
The ID of the job.
String
Output
Returns a string value of the specified job's description field.
Expression sample
The following expression returns the current job's description:
JobDescription($Job)
Example output
This is a landbase editing job.
JobDueDate
The JobDueDate expression returns the due date for the specified job in epoch format.
Parameters
JobDueDate(job_id)
Name
Explanation
Data type
job_id
The ID of the job.
String
Output
Returns a string value of the due date for the specified job in epoch format.
Expression sample
The following expression returns the current job's due date:
JobDueDate($Job)
Example output
1589414631
JobEndDate
If the specified job is closed, the JobEndDate expression returns the date that it was closed.
Parameters
JobEndDate(job_id)
Name
Explanation
Data type
job_id
The ID of the job.
String
Output
Returns a string value of the date that the specified job was closed in epoch format.
Expression sample
The following expression returns the date that the specified job was closed:
JobEndDate('RRpFaSk1QK2IIHZTJX4flQ')
Example output
1589416739
JobCreator
The JobCreator expression returns the username of the user who created the specified job.
Parameters
JobCreator(job_id)
Name
Explanation
Data type
job_id
The ID of the job.
String
Output
Returns a string value of the username of the user who created the specified job.
Expression sample
The following expression returns the username of the user who created the current job:
JobCreator($Job)
Example output
jdoe
JobComment
The JobComment expression returns the most recent comment associated with the specified job or step.
Parameters
JobComment(job_id, {step_id})
Name
Explanation
Data type
job_id
The ID of the job.
String
step_id
(Optional)
The ID of the step in the workflow diagram.
If an ID is not provided, the most recent comment associated with the job is returned.
String
Output
Returns a string value of the most recent comment associated with the specified job or step.
Expression sample
The following expression returns the most recent comment associated with the current job's specified step:
JobComment($Job, 'f50d740d-cc04-9296-4ce3-181e82604465')
Example output
The submitted feature edits are ready for your review.
$Job
The $Job variable returns the job ID of the current job. This variable is frequently used to dynamically populate the job_id parameter of other Arcade expressions.
Output
Returns a string value of the current job's ID.
Variable sample
The following variable returns the ID of the current job:
$Job
Example output
JobIndex
The JobIndex expression returns the index value associated with the chronological order of job creation. Jobs created before Workflow Manager 11.2 evaluate to a value of -1.
Parameters
JobIndex(job_id)
Name
Explanation
Data type
job_id
The ID of the job.
String
Output
Returns a string value of the specified job's index field. This is the value associated with the chronological order of job creation.
Expression sample
The following expression returns the index of the current job:
JobIndex($Job)
Example output
12345
JobName
The JobName expression returns the name of the specified job.
Parameters
JobName(job_id)
Name
Explanation
Data type
job_id
The ID of the job.
String
Output
Returns a string value of the name of specified job.
Expression sample
The following expression returns the name of the current job:
JobName($Job)
Example output
DataEdits_123
JobOwner
The JobOwner expression returns the username of the job owner.
Parameters
JobOwner(job_id)
Name
Explanation
Data type
job_id
The ID of the job.
String
Output
Returns a string value of the username of the job owner.
Expression sample
The following expression returns the username of the current job's owner:
JobOwner($Job)
Example output
jdoe
$ParentJob
The $ParentJob variable returns the job ID of the parent job to which the current job belongs.
Output
Returns a string value of the job ID of the parent job to which the current job belongs.
Variable sample
The following variable returns the job ID of the parent job to which the current job belongs:
$ParentJob
Example output
ZZfPSka12KQHHITZXJf4qL
JobPriority
The JobPriority expression returns the priority of the specified job.
Parameters
JobPriority(job_id)
Name
Explanation
Data type
job_id
The ID of the job.
String
Output
Returns a string value of the specified job's priority.
Expression sample
The following expression returns the priority of the current job:
JobPriority($Job)
Example output
Medium
JobStartDate
The JobStartDate expression returns the date that the specified job was started.
Parameters
JobStartDate(job_id)
Name
Explanation
Data type
job_id
The ID of the job.
String
Output
Returns a string value of the start date for the specified job in epoch format.
Expression sample
The following expression returns the date that the current job was started:
JobStartDate($Job)
Example output
1589414631
JobStatus
The JobStatus expression returns the status of the specified job.
Parameters
JobStatus(job_id)
Name
Explanation
Data type
job_id
The ID of the job.
String
Output
Returns a string value of the specified job's status.
Expression sample
The following expression returns the status of the current job:
JobStatus($Job)
Example output
Ready to work
JobType
The JobType expression returns the name of the job template from which the specified job was created.
Parameters
JobType(job_id)
Name
Explanation
Data type
job_id
The ID of the job.
String
Output
Returns a string value of the name of the job template from which the specified job was created.
Expression sample
The following expression returns the name of the job template from which the current job was created:
JobType($Job)
Example output
Data Edits
$newAssignee
Caution:
This variable is only available with email templates and must be used with the Assign Job automated action. This variable cannot be used in other parts of the web app.
The $newAssignee variable returns the username of the new user assigned to the job.
Output
Returns a string value of the username to which the current job has been reassigned.
Variable sample
The following variable returns the username to which the current job has been reassigned:
$newAssignee
Example output
jdoe
