Setting function
Available with Workflow Manager license.
The Setting ArcGIS Arcade expression allows you to retrieve user-defined settings. Because you can encrypt user-defined settings, workflow item administrators can securely store information such as credentials for a web request or commonly used file paths.
Learn more about configuring encrypted user-defined settings and where you can use them
Parameters
Setting(setting_name)
Name
Explanation
Data type
setting_name
The name of the user-defined setting.
String
Output
Returns a string value of the specified user-defined setting.
Expression sample
The following expression returns the value of the data_path user-defined setting:
Setting('data_path')
Example output
c:\data
