Dynamic job properties
Available with Workflow Manager license.
Use ArcGIS Arcade expressions to dynamically populate input values throughout a workflow. For example, you can use an Arcade expression to assign steps to specific users or groups based on the result of a step or send notification emails that contain job-specific information. You can also configure the Run GP Service step to use the JobLocation Arcade expression as an input parameter that's replaced with the extent of the job's location when the step is run. Every input value that supports Arcade expressions appears with the This input supports Arcade Expressions context menu that contains a list of expressions that can be added to its associated text box.
Use nested Arcade expressions to modify the output of other expressions. For example, use the following Text and Date functions to convert the output of the JobDueDate expression from epoch time to a more readable date format:
Text(Date(JobDueDate($Job)), 'dddd, MMMM D, Y')
To combine plain text and Arcade expressions, format the text as follows:
'Plain text' + ArcadeExpression() + 'plain text'
The following table contains an overview of the different categories of Arcade expressions specific to Workflow Manager:
Category
Job property functions
Retrieve job information managed by ArcGIS Workflow Manager.
Extended property functions
Retrieve custom business-specific information from extended properties tables.
Data management functions
Retrieve job data source and version information.
Location functions
Retrieve job location information.
Settings functions
Retrieve user-defined settings.
Workflow functions
Retrieve output values and past step assignment information.
A complete list of Arcade functions and global variables can be found on the Esri Developer site. The This input supports Arcade Expressions context menu contains the following expressions from the Arcade Function Index list:
Name
Arcade Expression
Current Portal
$currentPortal
Returns the current active portal.
Current User Details
var u = GetUser($currentPortal); return u['<key 1>'] + u['<key 2>']
Returns properties of the current user.
Current User Email
GetUser($currentPortal)['email']
Returns the current user's email address.
Current User ID
GetUser($currentPortal)['id']
Returns the current user's ID.
Current Username
$currentUser
Returns the current user's username.
Get User Details
var u = GetUser($currentPortal, '<username>'); return u['<key1>'] + u['<key2>']
Returns properties of a specified user.
Get User Email
GetUser($currentPortal, '<username>')['email']
Returns a specified user's email address.
Get Username
GetUser($currentPortal, '<username>')['username']
Returns a specified user's username.
User Groups
userGroups($currentUser)
Returns the ArcGIS organization group IDs for the current user.
