Location functions
Available with Workflow Manager license.
The following sections contain ArcGIS Arcade expressions that allow you to retrieve job location information managed by ArcGIS Workflow Manager. These expressions can be used for reporting and in tandem with geoprocessing tools and services to perform analysis.
GeoJsonToEsriJson
The GeoJsonToEsriJson expression converts the geometry of the first feature in the specified feature collection that matches the specified geometry type from GeoJSON to EsriJSON format and returns it.
Parameters
GeoJsonToEsriJson(feature_collection, geometry_type)
Name |
Explanation |
Data type |
feature_collection |
The feature collection that contains the geometry to be converted. |
String |
geometry_type |
The type of geometry to convert. |
String |
Output
Converts the geometry of the first feature in the specified feature collection that matches the specified geometry type from GeoJSON to EsriJSON format and returns it as a string.
Expression sample
The following expression converts a point feature from the current job's extended property table from GeoJSON to EsriJSON format:
GeoJSONToEsriJson(JobExtendedProperty($Job, 'assets', 'geojson'),'Point')
Example output
{\"x\":1.1354588060913904e7,\"y\":55660.45186542052}
JobLocation
The JobLocation expression returns the extent of the job location's geometry.
This expression only returns the extent of the job's location and does not return the job's location geometry.
Parameters
JobLocation(job_id)
Name |
Explanation |
Data type |
job_id |
The ID of the job. |
String |
Output
Returns an extent object constructed from the job's location in MinX, MinY, MaxX, MaxY, WKID format.
Expression sample
The following expression returns the extent of the current job's location:
JobLocation($Job)
Example output
9862243.197380835,5108823.353604797,-9801843.791879544,5133768.0805264525,3857
JobLocationGeometry
The JobLocationGeometry expression returns the geometry associated with a job's location. Supported geometry types include polygon, polyline, or multipoint objects. If the job location is not defined, the expression returns an empty string.
Parameters
JobLocationGeometry(job_id)
Name |
Explanation |
Data type |
job_id |
String |
Output
Returns the geometry object of the specified job.
Expression sample
The following expression returns the geometry object of the current job:
JobLocationGeometry($job)
Example output
"points":[
-13043713.699145492,
4033782.993028242
"spatialReference":{
"latestWkid":3857,
"wkid":102100
"paths":[
-13044121.111699998,
4033549.092400003
-13045645.036699997,
4035848.9540000223
"latestWkid":3857,
"wkid":102100
"rings":[
-13046377.218799999,
4036362.6929000057
-13046365.370699998,
4036363.148600001
4036372.262600016
-13046358.535199998,
4036344.920700025
-13046358.0795,
4036324.4144
-13046376.763100002,
4036324.4144
4036362.6929000057
"latestWkid":3857,
"wkid":102100
