Add and configure Create Replica
Available with Workflow Manager license.
The Create Replica step creates a replica geodatabase from a specified data reference using the Feature Service's Create Replica operation to enable offline editing workflows.
When creating offline editing workflows, this step is one of the first steps in the workflow diagram. Once the edits are completed, changes can be synchronized with the replica geodatabase using the Open Pro Project Items step and applied to the default version using the Reconcile and Post step.
When the step is run, the following actions can be performed:
  • Refresh Step —If you are assigned to the step or have the adminAdvanced or adminBasic privilege, re–check the status of the step if the connection to the server was disrupted.
  • Complete Step Complete Step—Finish the step.
At ArcGIS Enterprise on Kubernetes 12.1, workflow management services do not support the Create Replica step.
Configure the step
To configure the step, do the following:
  1. Create or edit a workflow diagram to access the Step Library panel.
  2. Drag Create Replica from the Step Library panel to a connection arrow of a step on the workflow canvas.
    Learn more about adding steps to a workflow diagram
    The Step Details panel appears.
  3. Provide a name for the step in the Step Name text box.
  4. Provide a name for the replica in the Replica Name text box.
    If no name is provided, the name of the current job is used by default.
    Caution:
    The replica name must not contain hyphens. Using hyphens in the replica name causes the step to fail.
  5. Provide the path to the folder where the replica will be created in the Replica Location text box.
    This can be a local or network file path. ArcGIS Workflow Manager Server must have read and write access to the specified folder.
    Tip:
    Click This input supports Arcade Expressions and choose an Arcade expression to add it to its associated text box.
  6. Configure the replica path location that ArcGIS Pro will use to access the replica by doing one of the following:
    • If you configured the Replica Location parameter with a file path, ensure that the Same as replica path location check box is checked.
    • If you configured the Replica Location parameter with a local file path, uncheck the Same as replica path location check box, and provide a path to the replica folder.
    • If Workflow Manager Server is deployed in a Linux environment, uncheck the Same as replica path location check box, and provide a path to the replica folder that is accessible from Windows.
    All users who will run steps that require access to the replica must have read and write access to the replica folder.
  7. Click the Data Source drop-down arrow, and choose a feature service data reference.
    Only one data reference can be configured with the Create Replica step.
    Tip:
    To create a replica for more than one data reference, configure additional Create Replica steps in the workflow diagram.
  8. If a data reference is not associated with the workflow diagram, add a data reference:
    1. Click Add data reference from the drop-down menu.
      The Add data reference dialog box appears.
    2. Add a data reference by doing one of the following:
      • Browse for item—Browse and choose from a list of items on the current portal.
        Tip:
        You can refine results by applying filters and tags to the search.
      • Enter item ID manually—Choose the environment where the data reference is located and provide the item ID and reference name in the Item ID and Reference Name text boxes. If you chose Other, provide the URL to the ArcGIS organization that contains the data reference in the Portal URL text box.
        The item is automatically validated by Workflow Manager and the data reference type is set.
        If the data reference cannot be validated, you must provide the item ID to a valid data reference that matches the set data reference type.
    3. Click OK to save the data reference, or click Cancel to exit.
  9. Optionally, add or remove sublayers by doing the following:
    1. Click Edit in the Sublayers section.
      The Select Layers dialog box appears.
    2. Check the Enabled check box next to each sublayer that you want to add or remove.
      All sublayers are included by default.
    3. Click Save to save the changes, or click Cancel to exit.
  10. In the Define Geometry section, choose one of the following options to define the replica's geometry:
    • Job Location—Use the location defined in the job.
    • Arcade—Provide a dynamic value using an Arcade expression.
  11. Optionally, check the check boxes in the Replica Options section to configure the following options:
    • Annotations and Dimensions—Include annotation or dimension feature layers.
    • Contingent Values—Include contingent values defined for the feature layer.
    • Utility Network Subset—Include utility network feature layers.
    • True Curves—Preserve true curves.
    • Attribute Rules—Include supported attribute rules.
  12. Click the Options tab.
  13. Configure Step Options as necessary:
    • Manual—Run the step manually.
      • Optional—Allow the step to be finished without being run.
    • Automatic—Run the step as soon as it becomes active.
      If the workflow diagram is configured to automatically run a sequence of steps that includes the Evaluate Data Quality or the Run GP Service step, steps that attempt to run after the user token expires will not run automatically. The ArcGIS Workflow Manager Server Advanced role is required to run additional automated steps without manual intervention.
    • Run on a Schedule—Run the step according to a set schedule.
      Learn more about scheduling options
  14. Optionally, choose one of the following options to configure help in the step:
    • None—Configure the step without step help.
    • Text—Configure help text for the step in the Text text box.
      You can use ArcGIS Arcade expressions to provide a dynamic value for the step help. If the step help contains plain text and Arcade expressions, format the text as follows:
      'For further assistance, please contact' + JobCreator($Job) + '.'
    • URL—Configure the step with a link to a help resource in the URL text box.
      Steps that are run in the web app only support HTTP and HTTPS URL formats. Steps that are run in ArcGIS Pro support HTTP, HTTPS, and file formats.
      You can also use Arcade expressions to provide a dynamic value. If the URL contains plain text and Arcade expressions, format the text as follows:
      'https://pro.arcgis.com/en/pro-app/latest/tool-reference/' + JobExtendedProperty($Job, 'tools', 'toolbox') + '/' + jobExtendedProperty($job, 'tools', 'alias') + '.htm'
      Configure the Automatically Encode Arcade Result check box as follows:
      • If an Arcade expression returns special characters that must be escaped when converted to a URL, such as a space or a forward slash, ensure that the Automatically Encode Arcade Result check box is checked.
      • If an Arcade expression is used to form the base URL, uncheck the Automatically Encode Arcade Result check box.
  15. Optionally, click the Style tab to change the shape and color of the step.
  16. Optionally, click the About tab and provide a description for the step in the Step Description text box.
    Tip:
    The About tab also contains the step's ID that can be used with dynamic job properties to obtain a step's output. Click Copy Step ID to copy the step ID to the clipboard.
Return value
When the step is completed, its return value is stored to indicate the result of the step. The return value can be immediately evaluated using paths to determine the next steps in the workflow. You can also retrieve the return value for completed steps throughout the workflow using ArcGIS Arcade expressions. The following table lists the step's return values:
Return value
S000001
The step completed successfully.
F000001
The step failed to complete successfully.
Output value
When the step is completed, its output value is stored and can be used to determine the path the workflow follows or can be used as inputs for other steps throughout the workflow. The following table lists the step's output values:
Output
dataSourceNames
Returns the data reference associated with the replica.
layers
Returns an array of layer IDs associated with the replica.
