Upgrade Workflow Manager Server
Available with Workflow Manager license.
The ArcGIS Workflow Manager setup package detects and upgrades an existing installation of ArcGIS Workflow Manager Server. Recent versions of Workflow Manager support a direct upgrade to the latest version. Older versions may require multiple upgrades to reach the latest version of ArcGIS Enterprise and Workflow Manager.
The following table lists the latest target version supported for a direct upgrade from each source version:
Source version
Latest target version supported for direct upgrade
11.1, 11.3, 11.5, 12.0, 12.1
12.2
11.0, 11.2, 11.4
12.1
10.8.1-10.9.1
11.5
Learn more about ArcGIS Enterprise upgrades
If you are using ArcGIS Enterprise on Kubernetes and intend to transition your deployment from a federated Workflow Manager Server site to using workflow management services, plan your deployment.
To upgrade Workflow Manager Server, complete the following steps:
  1. If you configured local resources for a disconnected deployment, create a backup of the appconfig.json file.
  2. If you are upgrading a high-availability Workflow Manager Server deployment, open ports 13820, 13830, and 13840.
  3. If you are upgrading from Workflow Manager Server 10.9 or earlier, upgrade to an interim version of Workflow Manager.
    If you are upgrading from Workflow Manager Server 10.9 or earlier, you must uninstall the Workflow Manager web app from your instance of Portal for ArcGIS. You do not need to uninstall the Workflow Manager web app before upgrading from 10.9.1 or later. The Workflow Manager web app automatically upgrades with ArcGIS Enterprise.
    Caution:
    If you are upgrading from Workflow Manager Server 10.9.X or earlier directly to 11.0 or later, you must remove and reconfigure the password in your email notification settings.
  4. Upgrade ArcGIS Enterprise to 12.2.
  5. Upgrade Workflow Manager Server to 12.2.
  6. Add properties to the Workflow Manager configuration file as necessary.
  7. Upgrade workflow items as necessary.
