+ (Unary Plus) operator
Resumen
Multiplies each cell value of the input raster on a cell-by-cell basis by 1.
Negate illustration
OutRas = + Raster("InRas1")
Debate
When using an operator with a raster input, the result will be a raster. However, if all inputs are numbers, the result will be a number.
When there are multiple operators in an expression, the operators are not necessarily run in left-to-right order. The operator with the highest precedence value will be run first. For more information, see the operator precedence table in Work with operators in map algebra. Use parentheses to control the run order.
If the input is integer, the output will contain integer values; if the input is floating point, the output will contain floating-point values.
If the input is a multiband raster, the output will be a multiband raster. The operator will perform the operation on each band in the input.
If the input is a multidimensional raster, all slices from all variables will be processed, and the output will be a multidimensional raster.
Operandos
Operando Explicación Tipo de datos
in_raster_or_constant
The input raster to apply the Unary Plus operator (multiply by 1).
Raster Layer | Constant
Entornos
Cell Size, Current Workspace, Mask, Output Coordinate System, Extent, Scratch Workspace, Snap Raster
Muestra de código
Unary + (Unary Plus) example 1 (Python window)
This sample applies the Unary Plus operator to the input raster.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
outUnaryPlus = + Raster("degs")
outUnaryPlus.save("C:/sapyexamples/output/outdeg")
Unary + (Unary Plus) example 2 (stand-alone script)
# Name: Op_UnaryPlus_Ex_02.py
# Description: Returns the cell valuesof the input raster on a cell-by-cell
#    basis.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inRaster = Raster("degs")
# Run Negate
outUnaryPlus = +(inRaster)
# Save the output
outUnaryPlus.save("C:/sapyexamples/output/outunplus")
