NbrAnnulus
Resumen
Defines an annulus neighborhood which is created by specifying an inner and outer circles' radii in either map units or number of cells.
Debate
Tools that use neighborhood annulus object: Block Statistics, Focal Statistics, Point Statistics, Point Density, and Topographic Position Index.
Licencia:
This class is also available if you have an Image Analyst extension license, but only for the Focal Statistics tool.
The annulus shape is comprised of two circles, one inside the other to make a donut shape. Cells with centers that fall outside the radius of the smaller circle but inside the radius of the larger circle will be included in processing the neighborhood; therefore, the area that falls between the two circles constitutes the annulus neighborhood.
When the annulus object is used and the innerRadius or the outerRadius are not specified, then default values are provided.
The innerRadius must be less than or equal to the outerRadius.
The radius is identified in cells or map units, measured perpendicular to the x- or y-axis. When the radii is specified in map units, they are converted to radii in cell units. The resulting radii in cell units produces an area that most closely represents the area calculated by using the original radii in map units. Any cell center encompassed by the annulus will be included in the processing of the neighborhood.
Sintaxis
NbrAnnulus({innerRadius}, {outerRadius}, {units})
| Nombre | Explicación | Tipo de datos |
innerRadius (Opcional) |
The inner radius of an annulus neighborhood. The default value is 1. |
Double |
outerRadius (Opcional) |
The outer radius of an annulus neighborhood. The default value is 3. |
Double |
units (Opcional) |
Defines the units of the neighborhood.
The default value is CELL. |
String |
Propiedades
innerRadius (Lectura y escritura) |
The inner radius of the annulus neighborhood. |
Double |
outerRadius (Lectura y escritura) |
The outer radius of the annulus neighborhood. |
Double |
units (Lectura y escritura) |
String |
Muestra de código
Demonstrates how to create a NbrAnnulus class and use it in the BlockStatistics tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
outNbrA = BlockStatistics("block", NbrAnnulus(1, 2, "CELL"))
outNbrA.save("C:/sapyexamples/output/blstatnbra2")
Implements the BlockStatistics tool using the NbrAnnulus class.
# Name: NbrAnnulus_Ex_02.py
# Description: Uses the NbrAnnulus object to run BlockStatistics tool.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inRaster = "block"
# Create the Neighborhood Object
innerRadius = 1
outerRadius = 3
myNbrAnnulus = NbrAnnulus(innerRadius, outerRadius, "MAP")
# Run BlockStatistics
outBlkStats = BlockStatistics(inRaster, myNbrAnnulus, "MINIMUM", "DATA")
# Save the output
outBlkStats.save("C:/sapyexamples/output/blstat_Ann3")
