TimeMultipleDays
Resumen
Defines a multiple day time period within a given year to perform solar calculations. A year, start day, and end day are specified.
Debate
This object can be used in the following tools: Area Solar Radiation, Points Solar Radiation, and Solar Radiation Graphics.
For multi-day time configurations, the maximum range of days is a total of one year (365 days, or 366 days for leap years). If the startDay is greater than the endDay, the time calculations will proceed into the following year. For example, [startDay, endDay] = [365, 31], represents December 31 to January 31 of the following year. In the example of [1, 2], the time is inclusive for the first day from 0:00 hours (January 1) to 0:00 (January 2). The startDay and endDay cannot be equal.
Specify the startDay, year, and endDay for a year interval. When the endDay is smaller than the startDay, the endDay is considered to be in the following year. This is the default time configuration.
Sintaxis
TimeMultipleDays({year}, {startDay}, {endDay})
| Nombre | Explicación | Tipo de datos |
year (Opcional) |
The Julian year. The default value is the current Julian year. |
Long |
startDay (Opcional) |
The The default value is 5, which is January 5th. |
Long |
endDay (Opcional) |
The The default value is 160, which is June 9th or 10th, depending if the year is a leap year. |
Long |
Propiedades
year (Lectura y escritura) |
The Julian year. |
Long |
startDay (Lectura y escritura) |
The |
Long |
endDay (Lectura y escritura) |
The |
Long |
Muestra de código
Demonstrates how to create a TimeMultipleDays class and use it in the AreaSolarRadiation tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
myTimeMultiDay = TimeMultipleDays(1980, 216, 244)
outAreaSolar = AreaSolarRadiation("solar_dem", "", "", myTimeMultiDay)
outAreaSolar.save("C:/temp/solarouttmd")
Calculates the incoming solar radiation with the AreaSolarRadiation tool using the TimeMultipleDays class.
# Name: TimeMultipleDays_Ex_02.py
# Description: Run AreaSolarRadiation using the TimeMultipleDays object.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inRaster = "solar_dem"
# Create TimeMultipleDays Object
year = 2004
startDay = 5
endDay = 6
myTimeMultiDay = TimeMultipleDays(year, startDay, endDay)
# Run AreaSolarRadiation using TimeMultipleDays Object
outAreaSolar = AreaSolarRadiation(inRaster, "", 200, myTimeMultiDay, 14, 0.5,
"NOINTERVAL", 1, "FROM_DEM", 32, 8, 8,
"UNIFORM_SKY", 0.3, 0.5)
# Save the output
outAreaSolar.save("C:/sapyexamples/output/areasolartmd2")
