TimeWholeYear
Resumen
Defines a year, using monthly intervals, to perform solar calculations.
Debate
This object can be used in the following tools: Area Solar Radiation, Points Solar Radiation, and Solar Radiation Graphics.
If the {each_interval} option is set in the tool parameter, then output files will be created for each month; otherwise, a single output will be created for the whole year.
Sintaxis
TimeWholeYear({year})
| Nombre | Explicación | Tipo de datos |
year (Opcional) |
The Julian year. The default value is the current Julian year. |
Long |
Propiedades
year (Lectura y escritura) |
The Julian year. |
Long |
Muestra de código
TimeWholeYear example 1 (Python window)
Demonstrates how to create a TimeWholeYear class and use it in the AreaSolarRadiation tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
outAreaSolar = AreaSolarRadiation("solar_dem", "", "", TimeWholeYear(2008))
outAreaSolar.save("C:/sapyexamples/output/areasolartwy")
TimeWholeYear example 2 (stand-alone script)
Calculates the incoming solar radiation with the AreaSolarRadiation tool using the TimeWholeYear class.
# Name: TimeWholeYear_Ex_02.py
# Description: Run AreaSolarRadiation using the TimeWholeYear object
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inRaster = "solar_dem"
# Create a TimeWholeYear Object
year = 2004
myTimeWholeYear = TimeWholeYear(year)
# Run AreaSolarRadiation
outAreaSolar = AreaSolarRadiation(inRaster, "", 200, myTimeWholeYear, 14, 0.5,
"NOINTERVAL", 1, "FROM_DEM", 32, 8, 8,
"UNIFORM_SKY", 0.3, 0.5)
# Save the output
outAreaSolar.save("C:/sapyexamples/output/mysolarout")
