Generate Airway Corridors (Aviation Tools)
Resumen
Simplifies the creation of airway corridors and flares for specified Air Traffic Service (ATS) routes.
This tool creates AirspaceArea features representing airway corridors and flares and populates attributes needed for charting purposes. You can also use this tool to provide airway floor data to split the created corridor and flares at specified locations where the airway floor elevation changes.
Uso
  • The required feature classes, tables, and attributes are described in the following table:
    Name
    ATSRoute (feature class)
    This tool will honor the selection and definition query on ATS routes.
    Enroute Information (stand-alone table)
    The table must contain the following attributes: GFID, Distance_Val, and Doglegpoint_Id.
    DesignatedPoint (feature class)
    Point geometry type.
    The feature class must contain the following attributes: GFID and Ident_Txt.
    AirspaceArea (feature class)
    Polygon geometry type.
    The feature class must contain the following attributes: Ident_Txt, LocalType_Txt, Type_Code, Class_Code, DistVertLower_Val, and DistVertLower_UOM.
    ChangeOver (feature class)
    The feature class must contain the following attributes: GFID and ATSRoute_Id.
    Airway Floors (stand-alone table)
    The table must contain the following attributes: RouteIdent_Txt, Description_Txt, StartPoint_Id, and EndPoint_Id.
    Precaución:
    This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
Parámetros
Input ATS Route Features
The input route segment features (polyline) for which corridors and flares will be created.
Feature Layer
Enroute Information Table
The table containing route information records that describe airways composed of one or more route segment polylines. Each record provides information such as the Route length and Doglegpoint_Id attributes.
Table View
Designated Point Features
The feature class containing point features that start or end route segment features.
Feature Layer
Target AirspaceArea Features
The feature class that will be used to store the generated corridor and flare features.
Feature Layer
Airway Floors Table
(Opcional)
The table containing airway floor descriptions that will be used to split the corridors and flares created for the route.
Table View
Create Flare for Route
(Opcional)
The route types that will have flares created. All route types will have corridors created, regardless of selection.
String
Route Flare Angle
(Opcional)
The angle in degrees that will be used to create flares for routes.
Double
Minimum Route Distance
(Opcional)
The minimum distance or length in nautical miles for a route to have a flare created.
Double
ChangeOver Point Features
(Opcional)
The feature class containing change over points for routes.
Feature Layer
Salida derivada
Updated AirspaceArea Features
The updated target airspace area feature class in which the corridors and flares will be generated.
Feature Layer
Entornos
Esta herramienta no utiliza ningún entorno de geoprocesamiento.
Información de licenciamiento
  • Basic: No
  • Standard: Requires ArcGIS Aviation Charting
  • Avanzado: Requires ArcGIS Aviation Charting
