Export Territory Solution (Territory Design Tools)
Resumen
Exports a territory solution to a feature class. The export includes records from all levels (hierarchy) of the solution.
Uso
  • A single feature class will be created with all levels.
  • The default value for the Output Shape Type parameter is set to the primary feature class type—for example, Boundary.
  • The following screen capture illustrates an example of three levels (three feature classes)—Base, Territory, and Region—exported into a single feature class. Geometry from base level and attributes of each base feature determine the territory or region to which it belongs.
    Export result
Parámetros
Input Territory Solution
The Territory Design solution layer that will be exported.
Group Layer; Feature Dataset; String
Output Feature Class
The feature class that will contain the exported territory solution.
Feature Class
Output Shape Type
(Opcional)
Specifies the feature geometry type to export.
  • Territory Boundaries—Polygon features that represent the territory boundaries will be exported.
  • Territory Centers—Point features that represent the territory centers will be exported.
String
Entornos
Current Workspace
Información de licenciamiento
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Avanzado: Requires Business Analyst
